Question about Craftsman Garden
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas tank is full and added oil. Why won't it crank?????
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Posted on Oct 13, 2010
Ford explorer 2007 v8 4.6 L Overheating in summer
chek if the electric fan is turning on when the ac is turned on
Jul 27, 2015 | 2007 Ford Explorer Eddie Bauer
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Carb replaced last may was still undr warranty used once last summer and once this year has not been used more than ten times since new ryobi refuse to help plenty of juice in the bulb but will not start...
If you had stored it with fuel in it, then the fuel has gone bad. That will cause it to not start. Today's fuel with ethanol is murder on small engines when stored with this fuel in it without stabilizer. This is not a design problem, it is a government problem with the mandating of ethanol added to the gas. This is a problem for ALL small engines. It is very common, and you are probably going to have to clean the carburetor, replace the diaphrams, replace fuel lines and fuel filter, and the primer bulb.
I hope this helps you get running again.
Sep 14, 2011 | Ryobi Garden
Damn! I have the same problem too... and I only used the machine once today for the first time..... only once.... i went and bought a bunch of ingredients and wanna try out some more recipes, but it...
The clicking sound is just the sound the unit makes when it heating up. Most bread machines do that. Many of them preheat because the ingredients have to be at the right temp to rise properly. If you paddle doesn't start turning after about 15 minutes then you have another kind of problem.
Oct 08, 2010 | Cuisinart CBK-200 Bread Maker
A.c. shuts off frequently
If you stored the unit upside down or sideways, the oil may have run out of the compressor. If the unit is reinstalled, it's important to let it sit in the correct position at least 24 hours before starting it back up.
Also check the condenser coil (the part of the unit that's sticks outside) and make sure it's clean. Likewise, check the filter and the evaporator coil (the coil on the inside) to make sure they are both clean.
Jul 07, 2010 | LG L8008R Air Conditioner
Can't get my Ryobi CS30 trimmer started, bought a new spark plug, still won't start. It worked fine last summer, took it out for the first time today, won't start, has plenty of fuel
Is the fuel old or has it been drained and refilled?? Sometimes old fuel will do this. Also make sure the air filter is clean and free of oil/dirt as this will also hinder the starting.
The primer button also is something to check. Push it 7 times, full choke, pull for 5 times, turn to half choke, and the unit should start.
Let me know,
Chip
Apr 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
Nov 30, 2009 | 1987 Ford F 250
Crank, no start 98 wrangler 2.5l
crank sensor likely-may be distributor sensor but my 98 sport was crank sensor situated in bell housing timed by flywheel
Sep 15, 2009 | 1997 Jeep Wrangler
Stalls, with oil runing out the exhaust
you have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Jun 29, 2009 | Garden
Air conditioner
Unit is low on Freon. Take it to a repair shop to find the leak & recharge the unit.
Jun 18, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Garden Logo
805 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
