My Panasonic FX-FL541 fax macnine is not working. The led display says 'ext. in use' and it won't let me do anything. The power is on and the phone jack is hooked up correctly toa fax line. HELP!
    Problem Solver:
  • 7 Answers
You may wanted to double check if the fax is connected to the phone jack and the cable modem. If it is, and it still doesn't fax... try pressing any key on the fax. Let me know if it works?
If it doesn't, here's a link to the dept...
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+Fax+Machines-UCM_PRD_CNT_002049
Posted on Jun 17, 2008
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
How can I reset Replace Drum on the Panasonic KX-FL511 Fax?
First of you will have to purcahse a Panasonic Drum Unit for you fax.
Inside the drum unit yu will have detailed instructions, you will open up the fax in the front take aout the old and install the new.
Here is a link to a helpful guild
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/How-To-Guides/model.KX-FL511.H#ts
Good luck
Nov 05, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
"low temp "error code : machine will not function
Hi:
The low temp error is most likely the result of a bad fuser assy that is not coming up to the proper temp. If if can't do that it will not work correctly. This would have to be serviced by a trained tech.
Andrew
Jun 26, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
THE FAX MACHINE CAN RECEIVE THE FAX IN THE MEMORY BUT FAIL TO PICK UP
My office fax machine can receive the fax in the memory, but it does not print it.
May 19, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Problem with new calls
Unplug and replug power cord.
Aug 18, 2008 | Office Equipment & Supplies
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Fax Problem KX-FL541
your scaner is dirty,you have maybe nsome stuck in the scanner,or correcton fluid gooes from document to scanner lamp,check is all ok ,if everythin clean,your scaner lamp has a damaged ,try to change it or call service man
Feb 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
64 people viewed this question
k24674
jasbo
jasbo
