I switched my thermostat to save money but now it is 85 in my house and it constantly is running but it is hot all the time my dad put it in so i know its right what is wrong with it
    Scholar:
  • 80 Answers
It may be wired incorrectly. Make sure that the compressor is being called to run when you set the ac to cool. The Green wire to T-stat makes the indoor fan run when you set the T-stat to cool...also the Yellow wire should signal the contactor to engage at the outside condenser and compressor unit. If this is a heat pump system there is usually an orange wire that will signal the reversing valve to move when cool is being called....normally the reversing valve is in the heating position in the event there is a failure to the solenoid that actuates it..thus leaving it to fail in the heat mode to provide heat in winter weather as a default. Make sure the new T-stat accomidates for your units wiring.
Red wire to R (24v supply from transformer)
Green wire to G (indoor fan)
White wire to W (call for heat)
Yellow wire to Y (call for cool)
Blue or Black wire to C (common)
Orange also to Y if not specific to t-stat (calls for reverseing valve in cooling mode)
Posted on Oct 13, 2010
I have a 1996 dodge ram 1500 running hot i have replaced water pump, radiator, thermostat, radiator cap, and checked all hoses and ran a block tester i am leaking no water why is it running hot water...
Sounds like u have an air bubble. Easiest way to get that out is jack the frt of the truck up as high as u can get it with the radiator cap off and run it
Apr 17, 2013 | 1996 Dodge Ram 1500 Club Cab
Readout says "HOT". fan stays on. Unit is not hot. Disconnected fan to save battery days later reconnected and still same. Is there a bad sending unit or T-Stat?
On a 2004 Sportsman 400 there is a sensor on the left side of the engine head, just under the thermostat housing. If that sensor is bad or disconnected the hot lamp will come on which causes the fan to constantly run. Good luck and if you need any more assistance let me know, Daniel.
Oct 27, 2012 | Polaris ATV
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Our hot water has been getting much more hot than usual - we don't run out of hot water, and the hot doesn't fluctuate between really hot and then cool. We had it set to a lower temp (~125F), so can...
The first thing I would do is to turn the thermostat up and down several times,wait a few mins. and do it again. Then run hot water until element comes on. Let it run for a few mins and then turn it back to lowest setting.
I never really came up with a good reason why this works some times but I always tried to save money for my customers and quite often I was 30 or more miles to supply house and it was a cheap fix.
I think you probably will end up replaceing thermostat like your thinking so good luck. Thank you.
Dec 27, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have an old RUUD central AC unit that started blowing hot air. I set the thermostat to off and set the temp gage higher than air temp to turn the unit off and save money, but inside blower unit runs...
Hello
Okay did you check your thermostat to see if you have the fan switch on auto? The switch must be on auto or the fan will continue to run. If the thermostat fan switch is on auto then there is a malfunction in the thermostat probably. You can go to your forced air unit and on unplug the unit. That way it will not turn on at all, because the forced air unit is controlled by the thermostat. Hope this helps.
Jul 26, 2009 | Heating & Cooling
Over heating
check to see if fan motor or fans are running with ac on,,,if not check the fan relay and fuses
Jul 06, 2009 | 2003 Mercury Mountaineer
Just a little question, guys!
The blower has absolutely nothing to do with outdoor air. Having the T-Stat set to auto lets the blower come on only when the A/C-heat comes on. With the switch in the ON position the blower simply runs all of the time. Depending on your living space (high ceilings, multi-level) having the blower on constantly while costing a small amount to run can actually save some money and make you more comfortable in the summer. However most people will leave it in auto in the winter so they don't feel as if they have a draft from the air movement as the blower is in high speed in fan on position and cool modes and low speed in heat mode. Many furnaces today are equipped with a setting that allows the blower to run constantly at a lower speed or simply run for a min. or two after the A/C=Heat have turned off.
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Coolant bizarre behavior
if car doesn't run hot with no thermostat...you may be air-locking system when installing thermostat. I always fill the engine block up to the thermostat housing to make sure that engine is full of fluid ..then install thermostat...spring facing down..thenfill radiator making sure car is running so as not to air lock system ...run until top hose gets warm ,showing that your thermostat opened
Nov 23, 2008 | 1998 Chevrolet Cavalier
MEMORY PROBLEM
it sounds like your hot wire and memory wire are crossed you need to place your constant +12v wire to a source which is always hot and your memory wire to your ignition when you turn on your car it all works fine
Dec 13, 2007 | Alpine CDM-7833
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
