Question about Whirlpool Washing Machines
Whirlpool duet GHW9160PW0. Front load washer is leaking water inside the drum after the cycle runs and clothes are removed water builds up on the inside.
gittos73
  • 244 Answers
SOURCE: Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Posted on Sep 12, 2007
  • 126 Answers
SOURCE: How to remove drum
i would call a service tech,it is not easy
Posted on Jan 13, 2008
SOURCE: Whirlpool Duet Washer Leaking
Thanks Master Tech! I removed the lint clean out and found some chewed up change. I cleaned it, put it back and ran a load. It usually fills up overnight. So far it looks good!
Posted on Feb 15, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool duet washer has rock, marble, or something stuck inside
as long as your sure its an item between the tub assy the baffles in the drum can be removed and item fished out. but ifsomething snapped on the rear of the drum you would need to replace it. the baffle part number is 8182233, its about $40 thinknin thats worth a try before 475. the lower acess panel could also be removed and the main tub to pump hose could be removed which would give you a 3in hole to look through and try to grab somethin. worth a try
Posted on Mar 07, 2008
  • 185 Answers
SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Posted on Mar 28, 2008
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: I find water in the drum after i have washed cloth...
Check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When cleaning the washing machine it stopped and the RL came on. What is RL?
RL means at the start of the CLEANING WASHER cycle a load isdetected inside the drum.
Try removing clothes from drum and start the cycle again.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
There is a build-up of an orange colored residue in the front window of our front load washer, which is now all over the last load of white clothing I just washed. What is this and how do I remove it from...
the best thing is wash the window with CLR its sold at all hardwares,and run a cycle with CLR,put it in where you put the detergent,use hot water,this should take care of the problem
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW0 water in drum, stinky cloths
the flapper in the pump which acts like a check valve is bad chances are check this first
Jul 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to remove drum
Jan 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
