Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile PFSF5 NJWA BB
Is there a reset...my freezer door was cracked open...everything melted overnight...The compressor sounded very loud for a while. The temperature Freezer temp won't get lower that 38 and fridge temp is stuck at 44. Is there a reset mechanism? I can't find my book for troubleshooting...
  • 828 Answers
There is a timer that determines the defrost of the cooling coil inside the back wall of the freezer. defrost timer may be located in the area of the controls for temperature. Look for a hole in that area and recessed in that hole you may find a clutch head screw. Turn this screw clockwise very SLOWLY until you hear one click. The freezer coil will be in the defrost mode for 18-22 minutes and then the refrigerator should return to the cooling mode. Make sure the condenser is clean and free of dust and dirt. Condenser is where the heat is removed from the refrigeration system and on most models it is located in back behind a removable panel. Reinstall the panel after cleaning the condenser.
Posted on Jun 01, 2008
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
My ge profile pfs22sbsss model french door freezer drawer was left open overnight and now won't get cold. Any ideas?
THE FREEZER HAS FROZEN PAST THE POINT OF DEFROST;TURN FRIDGE OFF AND MANUALLY DEFROST ALL THE ICE IN THE FREEZER SECTION AND ALL AIRWAYS TO FRIDGE SECTION.
May 10, 2014 | Refrigerators
Temperature issues in GE Profile Refrigerator Freezer, what to do?
Sounds like an inefficient compressor or possible overload/relay issue
Jul 25, 2013 | Maytag MZD2768G Side by Side Refrigerator
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile PSC23. Everything works fine
I fixed it myself. After poking around the freezer, I saw that the area around the tube that gets water for ice making was frozen - this is at the top of the freezer. So I used a hot spong to melt the ice and the noise went away. Everything is working fine now.
Jun 17, 2009 | GE Refrigerators
GE Profile
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
My freezer is buzzing- loudly!
Sounds like ice buildup around the fan that's inside the freezer.  My lousy GE 3-door did that when the bottom freezer didn't get completely closed overnight, and everything behind the back panel, where the coils are froze up like an iceberg.  I had to take the back panel off and melt it with a hair dryer.
See if you see any abnormal ice buildup, or if the refrig compartment is getting warm.  That's usually a result of ice buildup.   Another cause is a failure in the defrost cycle.  It will freeze up after a couple days. This would usually be the defrost timer.
Oct 23, 2007 | Refrigerators
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
319 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
