Question about Stairmaster 4100PT Stair Climber
Stairmaster 4100pt levels will not change..too much resistance have to push pedals down with all my strength it wax working then just got too hard to get pedals down.
4 Suggested Answers
  • 49 Answers
SOURCE: STAIRMASTER 4600CL RIGHT PEDAL LOSES RESISTANCE AND SLIPS
http://support.nautilus.com/support/stairmaster.jsp?lid=StairMaster you can download and view all manuals here. If by drive sprocket you mean the hub that both step chains go over.....replace the entire hub. faster easier and less hassle. cost difference is about 40 dollars.
Posted on Sep 01, 2009
SOURCE: stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Posted on Dec 09, 2009
maxtreadmill
  • 832 Answers
SOURCE: stairmaster pedal slip
Sound s like it maybe the hub assembly they have a one-way bearing in them and that could be cause the problem go to
http://www.gympart.com/ or call them 1-800-496-7278 they will have the parts for your
Posted on Apr 11, 2010
4100pt
Stairmaster 4100PT Stepper Parts SPORTSMITH net
You can use the above link to get some more information on this unit. We have several parts available as well as the manual for this model. It sounds like you could be dealing with either a faulty keypad or a bad display.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Mar 12, 2014 | Stairmaster Exercise & Fitness
I have a 440pt and the left pedal is skipping down to the floor about every 5 seconds. If the issue is the hub assemble, do I have to change out everything or can I just replace the bearing, etc...?
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Sep 05, 2013 | Stairmaster 4400PT FreeClimber
I need power supply details
This link will take you to information for the power supply on a 4100PT Stairmaster stepper.
SM 4100 Power Supply SM25726 SPORTSMITH net
Aug 27, 2011 | Stairmaster 4100PT Stair Climber
I changed out a chain and spring on my stairmaster 4100pt. Now the unit will not turn on. Is there a reset button somewhere?
You may consider retracing your steps to see if, while removing and then installing those components, a wire(s) didn't get bumped loose
Dec 23, 2010 | Stairmaster 4100PT Stair Climber
My right pedal on my 4600 cl goes right to ground i belive the bushing is bad on the leveling arm the left side pedal is good and i nice and tight on the shaft where the right side was loose do u think the...
Dec 05, 2010 | Stairmaster 4600PT Stepper
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
Stairmaster Spinnaker 3000 CE exercise bike user
http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C3000CE_3600RC%20Spinnaker%20Manual.pdf
May 02, 2009 | Stairmaster 4100PT Stair Climber
Stairmaster 4100PT Stair Climber Logo
124 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
