Question about Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive
Buffalo HD-HC250.. Saved pics onto this hd from a PC. Hooked it up to a Mac, opened a photo, made a cropping. Says "Read Only"; and I can't "save as". How to remedy?
Crankstart
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 09, 2009
bob_computer
  • 3153 Answers
SOURCE: I cant format my Buffalo HD-CE500U2. It took time
A few things to check
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there then lets see if we can format it ?
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Posted on Aug 23, 2009
SOURCE: Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
Posted on Jan 31, 2010
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
lock123
  • 6831 Answers
SOURCE: our power went out and now the Buffalo HD in not w...
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
How do I crop a photo that has been sent to me via next text message that is saved in my gallery?
Download the best photo editor onto your phone as an extra app, then open the photo via the app and edit.
Mar 23, 2015 | Cell Phones
Tip
HD Video to Blackberry Converter for Mac to Convert AVCHD,MOD,MKV Files to...
BlackBerry, functions as a personal digital assistant with address book, calendar and to-do list capabilities, is a line of mobile e-mail and smartphone devices. It also functions as a portable media player with support for music and video playback and camera picture and video capabilities.
People who have Blackberry may satisfy convenience of their portable smartphone, but they will be upset that Blackberry cannot directly playback HD videos like MKV files, AVCHD MTS/M2TS, MOD files shot by JVC, Sony, Panasonic Canon HD camcorders. Why? Let's look at the supported audio and video file formats on Blackberry:
Audio: mp3, m4a, wma, wav
Video: mp4, mov, 3gp, 3gp2, avi, asf, wmv
So for Blackberry for Mac users, if you would like to enjoy HD video such as MTS, M2TS files, MOD files, MKV files with the most popular smartphone---Blackberry Curve 8300 series, a professional HD Video to Blackberry Converter for Mac can easily help you convert HD videos including MTS, M2TS, TS, MKV, MOD, TOD, MPEG2 HD, MPEG4 HD, WMV HD to Blackberry for Mac. It can also convert audio MP3, WAV, AAC, AC3, AMR, MP2, FLAC, OGG and AIFF to all popular audio formats and extract audio from video to MP3, WMA, AAC, etc.
Quick guide offers you to convert HD video and movies to Blackberry for Mac step by step.
Step1: Input HD Video to HD Video to Blackberry Converter for Mac
Click "Add File" to upload HD Video files or HD Movies, such as AVCHD MTS, M2TS, MOD, MKV files from your computer hard drive. You can add batch of HD videos one time to save time.
Step2: Set Output Video Format for Blackberry
Click to open "Profile" to select MP4, 3GP, or MOV from the Profile drop-up list as output video format for Blackberry on Mac OS.
Step3: Convert HD Video to Blackberry on Mac
Press "Start" button to transfer MTS, M2TS, MOD files, or MKV videos to MP4, 3GP(AAC) to Blackberry on Mac.
Tips: Mac HD Video to Blackberry Converter also own powerful editing fuctions such as trim HD video length, merge several HD videos, remove unwanted black edges through cropping, capture video snapshots, etc. More info you can refer to Doremisoft HD Video Converter for Mac and edit HD video on Mac.
on Sep 29, 2010 | Computers & Internet
Tip
HD to audio ? Convert HD to audio to extract audio from HD videos on Mac
Some users may want to extract audios from their HD videos. Their HD videos may be either from HD movies or HD videos clips taken by themselves, and these HD videos have good background music or sound that they want to extract and save in MP3, AAC or other audio formats.
If you are running Mas OS and want to convert HD to audio, Doremisoft
Mac HD Video Converter will be the perfect choice because this application works perfectly to convert HD to MP3 and HD to other audio formats with excellent quality. To convert HD to audio on Mac, you can just follow the steps below:
Step 1: Import HD video to Mac HD Video Converter
Click the "Add File" button to add the HD videos you want to convert to iTunes
Step 2: Select an audio format to convert HD to audio
Click to open the "Profile" drop-up list, move your mouse pointer to "Common Audio", and you will see all the preset HD formats from the right menu. Click on the format you prefer to select it.
You can find that most common audio formats are available here, so you can convert HD to MP3, HD to AAC and HD to XX and so on.
Tip 1: Tick the "Apply to all" button to apply the selected audio format to all the added HD files.
Step3: Convert HD to audio
Click on the Start button on the lower right corner of the main interface to start converting HD videos to audio.
After the conversion, the folder where the extracted audio formats are saved will be opened,a nd then you can put them into your audio players to enjoy your favorite movie music!
Click here to see detailed info of Doremisoft HD Video Converter for Mac
on Jul 30, 2010 | Microwave Ovens
Does not read on the mac
If the USB hard drive was formatted in NTFS on a PC then the MAC cannot read this hard drive.
If you format this hard drive on a PC in FAT32 file format then the MAC can exchange data between the MAC and the PC.
The MAC can read and write PC data to this hard drive.
Oct 15, 2012 | Buffalo Tools (HD-PE500U2/RD) 500 GB USB...
I had a job open over night (I have done this many times) and came to "wake" it up, then make sure I had saved the job, saved it...it froze (meaning it never stopped trying to save on my Mac) so...
Hi Hap,
We do offer phone support here at FixYa but you need to request it through the system as it is a paid service. If you need to find the files you worked on the two best utilities for recovering the working files ar disk warrior and Stellar Pheonix. There is a good review of Stellar on http://www.aitsavemyfiles.com/reviewstellarpheonixmacdatarecovery4.php
If you need further help or wish to have phone support log back in and request assistance and one of our agents will help walk you through this issue.
Hope this helps FixYa,
Chris
Dec 19, 2010 | Buffalo Technology DriveStation Combo 4 1...
Tip
Mac HD Converter ? The prefect HD video converter to convert HD video on Mac OS
Doremisoft HD Video Converter for Mac is the perfect Mac HD converter to convert HD video and convert video to HD on Mac OS. It can convert HD videos such as MTS, M2TS, TS, MKV, TP, TRP, M5S, MOD, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD etc. and regular videos such as AVI, ASF, MPEG1, MPEG2, MPEG4, MOV, FLV, 3GP, 3G2, DIVX, M4V etc. to various video formats and almost all players.
Doremisoft HD Video Converter is for Mac also an excellent Mac audio converter, it can convert all sorts of popular audio formats such as MP3, WAV, AAC, AC3, AMR, MP2, FLAC, OGG and AIFF to all popular audio formats so you can play your music on different players. With Doremisoft HD Converter for Mac, you can also convert video to audio and extract audio tracks from your favorite video files.
Doremisoft HD Video Converter for Mac is also an easy HD video editor to edit HD video on Mac by cropping HD video to remove unwanted sides or area, trimming HD video length to capture clips from your HD video files, editing video effects such as brightness and contrast, applying special effects etc.
Key Features of Doremisoft HD Converter for Mac
Convert HD video to different formats and players on Mac
Work as an excellent MKV converter/MOD converter/MTS converter/TOD converter. Convert various HD video formats including MTS, M2TS, TS, MKV, TP, TRP, M5S, MOD, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD, Flip MP4 HD to various formats such as MKV, 3GP, 3G2, MPEG1, MPEG2, MPEG4, FLV, SWF, DV, M4V and MOV and so on, and to all sorts of players including iPod, iPhone, Apple TV, PSP, Creative Zen, cell phones, Zune, BlackBerry, Gphone, iRiver, Palm, Walkman, Gphone etc.
Convert regular video to different formats and players on Mac
Convert regular video formats including AVI, ASF, MPEG1, MPEG2, MPEG4, MOV, FLV, 3GP, 3G2, DIVX, M4V etc. to various formats such as MKV, 3GP, 3G2, MPEG1, MPEG2, MPEG4, FLV, SWF, DV, M4V and MOV and so on, and to all sorts of players including iPod, iPhone, Apple TV, PSP, Creative Zen, cell phones, Zune, BlackBerry, Gphone, iRiver, Palm, Walkman, Gphone etc.
Convert video to HD format on Mac
Convert HD video to other HD video formats and convert regular video files to HD compatible formats.
Convert audio to audio and video to audio on Mac
Convert all sorts of popular audio formats to one another for playback on all major players, and extract audio from HD video and regular videos to output in popular audio formats.
Merge multiple videos
Join and convert multiple separated HD videos and regular videos to one single file.
Trim HD video length
Capture video clips from HD video and regular video to only convert your favorite parts.
Crop video
Crop to get rid of redundant parts such as the black sides around your video and any part you want to remove.
Edit video effect
Edit video brightness, contrast and saturation, and set special video effects such as embossment, old film, gray etc.
Instant preview
Come with two preview windows to let you preview the editing results real time.
Capture video snapshots
Take snapshots off videos and save the snapshots as JPG, PNG or BMP.
on Jun 21, 2010 | Computers & Internet
Tip
Edit HD video files on Mac with HD video editor for mac OS X
HD(High-definition) camcorders and HD TVs are now taking over the market. Many users might have just got their HD camcorders. However, a lot of HD camcorder users may be experiencing difficulties editing their HD video files, especially on if they are running Mac OS. Many HD camcorder files are encoded by AVCHD, which is not supported by many editing applications. Mac HD Video Converter is not only a great Mac converter for HD videos, but also an easy HD video editing software for Mac users. It can edit AVCHD, MKV, TOD, TS, TP, TRP, Flip HD MP4 etc.
HD editing (editing AVCHD, editing TS/TP/TRP, editing HD MKV etc.) with this HD editor is easy. You just need to install Doremisoft Mac HD Video Converter and follow the steps below:
Step 1: Import AVCHD (or other HD) files
Click the "Add File" button to browse your hard drive and import flip videos to thisHD editing software.
Step 2: Edit HD video
Click on the Edit icon from at the top of the main interface to open the editing window. And now you can:
1. Crop HD video
You will first see the Crop window, if you want to crop your HD video, just drag the crop frame to specify the area you want to crop. Or you can set the crop values on the lower part of the screen.
2. Edit HD video effects
Click on "Effect" tab on the lower left of the editing window, and you will see the options to let you edit video effects. You can set video brightness, contrast and saturation, and apply a special effect such as gray, old film or emboss
3. Trim HD video length
If you want to trim the length of your HD video, click on Clip icon at the top of the main interface to open the Clip window. Then trim HD video length using one of the three methods as shown on the figure below:
Step 3: Convert HD video
Now, you are done editing HD video. Click the "Profile" drop-up list, and click on the profile you prefer to select it. Then, click on the Start button on the lower right corner of the main interface to convert your HD videos to the desired formats.
If you want to edit your HD videos in iMovie, click here to see how to import HD to iMovie.
Opening saved Gimp file
Hi Amber.
If I read rhe above correctly, you have got your last saved image back. You had only marked out areas to crop, you hadn't cropped them.
It follows then that you hadn't made any changes to the file.
Sep 13, 2009 | GIMP GNU Image Manipulation Program
Pictures saved on phone looks distorted
Copy the photos to your PC via the data cable provided or bluetooth. use Paint to crop them and transfere them back.
should take 5 mins no new software needed.
Jan 06, 2009 | LG Shine KE970 Cellular Phone
Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Logo
138 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
