Speaker not working
Hi
please help, built in speaker in flat pannel monitor not working, product no MA782KC, MODEL NO.700P.
windows xp pro operating system.
CHECK IF THE SOUND DRIVER HAS INSTALLED PROPERLY OR THE ONBOARD SOUNDCARD HAS BEEN DETECTED OR NOT.IF NOT DETECTED TRY THIS: 1.INSTALL XP AGAIN. 2.TRY REMOVING ALL SOUND RELATED APPLICATIONS AND RESTART THE MACHINE SEVERAL TIMES.
Posted on Jun 01, 2008
  • SHRAMAN CHAKRABORTY Jun 01, 2008
    ALSO CHECK THE CONNECTING WIRES WITH THE CPU AND LCD
Cant get mag 700p monitor to work with toshiba satellite
I HAVE DOWNLOADED resident_evil_4_1.10_eur AND WHEN I CLICKED TO INSTALL IT :INSTALLATION DESTINATION NOT FOUND; IS GIVEN AS ERROR. SOLVE MY PROBLEM PLEASE
Oct 30, 2009 | Computers & Internet
Built in speakers not working
Please try to check it from Control Panel > Sound, speech & audio devices > Sound and Audio Devices > Hardware tab > then select the Device Name then click Properties tab to verify its condition status or you opt to click Troubleshoot tab. regards
May 12, 2009 | Proview PX 780 Monitor
KDS product 17s, model 700p. I am getting the follwing message "mode not supported H 82.8khz V77.7hz" whenever I boot the computer. I cannot escape from the message. The computer it is attached to is...
Start in SAFE mode (press F8 wile booting) and choose SAFE mode from the menu to see if it works in Windows DEFAULT setting. Then reboot and reset to 32Bit, and 78Hz max.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Good Luck!
Let me know if this fixes it
Mar 26, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
Hi, I have a problem with
The high voltage (HV) flyback transformer is a very possible cause of this. This could be repaired by a qualified technician, but the cost may not be worth it. New 17" monitors can be acquired for free sometimes (think craigslist)
Mike
Mar 31, 2008 | Computers & Internet
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
150 people viewed this question
 Grubhead
Grubhead
