Question about RCA P52930BL 52" Rear Projection Television
Unusable signal This morning tv will only display unsuable signal. What are some reaons for this and some solutions? It was working fine yesterday
Had the same problem unplug the tv for hour. Had ours at the tv repair shop and it worked fine there brought it home now we have a great picture but no sound.
Posted on Dec 16, 2008
No sound
TV was working okay yesterday The screen is showing no signal when I turned it on this morning, I check the cable hookup
Nov 19, 2013 | Olevia LT42HVi 42 in. LCD Television
Htc mobile not tyrn to on,pleasetell me what is the reaon
power issue..
were you plug it the charger in there is connectors, you will be able to see the pins..
on the outer part of this is 2pins barely visable, you need to get a pin and pull the connectors out a little.
only a little as you might snap them.
use a pin!
its wat im doing at the moment..
hope this helps
Dec 20, 2009 | HTC P3300 Smartphone
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
Blank screen when wii is on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-108
May 26, 2009 | Nintendo Wii Console
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv
im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
May 10, 2008 | RCA P61960 61" Rear Projection Television
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
