Question about Craftsman Garden
No start condition;spark plug fouls out with gasoline(wet)when attempting to start,(..even without pushing the primer at all) ...new spark plug was installed and still fouls with fuel(no prime was given either)after three pulls on rope(coil)
  • Craftsman Master
  • 7,482 Answers
Cean your air filter, it will cause the condition of flooding that you described.
Please rate me
Posted on Oct 13, 2010
The cylinder is filling with gasoline after the blower is shut down. and will not start even after purging the cylinder with the spark plug out. yes the spark plug is reinserted to attempt starting
yes you inserted it but did you dry and or clean it a wet or fouled plug wont spark and also if didnt correct excess fuel wont fire up either
Oct 28, 2016 | Garden
New kohler 6.5 hp engine on 27 ton log splitter won't start? Switch on, throttle 1/3 open gas on, has gas. Choke on, which direction?
After attempting to start, pull the plug quickly and see if it is wet from gasoline. If not, it could be a fuel delivery problem. Start with the hose connection at the carb from the gas tank. Pull it off. Gas? Good. No Gas? Something is plugging up flow out of tank or shut off valve.
Some fuels with alcohol in them cause moisture/
condensation/ oxidation within the aluminum bodies of some small carbuetors inhibiting the flow of gas through the jets. There is a chance the carb needs removed and thorougly cleaned if no gas is passing through the carb to the intake.
Also inspect plug for fouling. Fouling is carbon build up shorting the electrode to ground. Clean thoroughly or replace the plug. Before reinstalling, set the spark gap properly with a feeler gage and then ground the metallic threads on the side of the head and pull the rope start. Watch closely for blu spark jumping the gap. DO NOT touch the plug while doing this, it could SHOCK your SOCKS off !!!! If you have a bright spark, that's good. Install plug and tug the rope and see what happens. If you have no spark, you have an ignition problem.
Are you using summer blend or winter blend gasoline in the engine and what is the outdoor temperature. Gasolines are formulated differently nowadays and a summer blend mixture will wreak havoc on a small engine in the winter time as well as winter blend will do the same in the middle of the summer. We now have oxygenated fuels designed for the high performance engines in the automobiles today and some small engines run extremely 'lean' and as a result some starting issues are created as well.
Nov 29, 2014 | Heavy Machinery
Procedure how to start new mower
Make sure you have the proper amount of oil in the engine
Make sure your new blade is on tightly. Pull spark plug wire off.Check and see if you can turn the blade by hand one complete turn to make sure nothing is holding blade back. Sometimes the factory puts a block under neath for shipping. Replace spark plug wire.
Fill with the proper gasoline
Should be ready to fire up. Push primer bulb three or four times and pull cord and it should run. Sometimes you have to push primer bulb more than they recommend in the book.
Sep 29, 2014 | Craftsman Garden
Craftsman
Larry - the manual isn't really going to help you get this started. Press the primer bulb - if provided a couple of times to get gasoline into the cylinder. You may hear it squirt - or even see it drip from the carburetor. Try starting. If it didn't, remove the spark plug. Is it wet with gasoline? Is the chamber filled with gasoline fumes (you can slowly pull the starter rope to move the piston up and force the air in the cylinder out to smell for gasoline). It wet, dry it throughly. If there is no gasoline odor, give a brief spray of starting fluid or ether into the spark plug opening - and install a new plug - or the clean old one. Attempt to start again. If it tries to start and sputters, you likely have a fuel delivery issue. Make sure the shut off valve at the bottom of the tank or inline on the fuel line is open. If it is, I suspect that the float in the carburetor or needle valve needs to be cleaned / adjusted or replaced. You may want to have this done for you as there are some very small parts involved and attention to detail when re-assembling will be required. Carburetor rebuild kits are available for most of these engines.
Mar 02, 2014 | Craftsman Snow Blower 22 In. Dual-Stage...
1993 HD fatboy won't start. has spark and fuel and turns over
Hi Leon, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
Good luck
Jan 05, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
Sportster 2001 883 has spark but will not start
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
For a primary suspect please visit the website below:
Harley Davidson Sportster error codes and how to access them
Good luck
Apr 28, 2012 | Harley Davidson XLH Sportster 883 Hugger...
Spark Plug gets wet too fast
Air filter may be blocked and inspect exhaust baffles and clean.
Apr 29, 2010 | 2000 Gas Gas EC 200
My truck starts most of the time but has failed to turn over twice in 2 dats but then evetually will start..is this a clogged injector or pressure regulator..03 ranger edge
The typical symptom of problems with the injector are, stalling , hesitation and fouling of spark plugs. You should even see the spark plugs wet with gasoline. Otherwise check the status of the spark plug if it needs replacement or even the timing.
Aug 26, 2009 | 2007 Ford Edge SEL Plus
Ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
172 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
