Question about Weather King Heating & Cooling
Weather king air conditioner
Fan on unit runs about 30sec then loud noise and stops
Sounds like you have bad bearings in motor if compressor continues to run.
Posted on Jun 01, 2008
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
AC was running all this summer, then suddenly stopped working. The fan runs on auto and manual but the outside unit does not come on.
The indoor fan is running . but the compressor and outdoor fan does not come on . check fuses there should be a disconnect on the outside by the unit it may have fuses. one could be blown. if the unit has a curcuit board see if any light are falshing. let me know
Jul 23, 2011 | Weather King 10AJA6001AH Air Conditioner
Weather king model 13pja36a01 Heat pump The outside fan runs slowly, compressor starts then immediately stops. I replaced the run capacitor, I believe this might be the fan motor going bad but I...
If you have replaced the run capacitor and the fan still is running slow you definitley need to replace the motor no doubt. you can go online to Grainger.com or find one by your house. Your compressor is going off immediately because high pressure thats a good thing. Get a new fan and a new capacitor and you should be good.
May 09, 2011 | Weather King 10AJA3601AH Air Conditioner
Fan over compressor making noise
Fan needs to be replaced. If left to long, it will sieze and stop at the most inopportune time. If not caught quickly the compressor will overheat and burn out. Not to mention the temp will be effected.
Sep 20, 2009 | Weather King 10AJA4201AH Air Conditioner
The outside unit is running, but the inside air handler unit does not work? The blower is not working, but you can hear a clicking noise.
turn the power off to the indoor unit and see if you can spin the fan by hand. the bearings may be locked in the motor. if so you need to replace your blower motor. let me know what you find out
Jun 13, 2009 | Weather King 10AJA2501AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
A/c unit
check the fan timer if equipped. check stat wireing and make sure it is on auto. remove wire on g from stat and motor should stop.check for power to motor and remove on control or wire at a time unit it stops running
Dec 28, 2007 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
