Question about Refrigerators
How do I change the light bulb in my Westinghouse Freestyle fridge? I can't seem to get the cover off. Thanks.
5 Suggested Answers
rpbuice
  • 161 Answers
SOURCE: we have a westinghouse freestyle
You will have to remove the freezer shelves and Icemaker then you should see the screws which hold the back panel in place. Remove these screws and you should be able to remove the back panel.
Posted on Dec 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • 51 Answers
SOURCE: im after a manual for
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Posted on Oct 24, 2010
  • 3 Answers
SOURCE: I have a westinghouse freestyle fridge and it is
Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Posted on Jan 08, 2011
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
JUST WANT TO CHANGE THE LIGHT
I am assuming we are talking about a compartment light. Most every brand the light over has lock in tabs that you release with your fingers by GENTLY squeezing the light bulb cover from one side. Only one side will unlatch. The other side is locked and you have to pivot the cover to about a 40 Deg angle to remove it. Grip the socket so it does NOT flex, unscrew the bulb and install the new bulb. To reinstall the cover... tilt it to align the locked tabs and then GENTLY squeeze the cover again to engage the last 2 tabs.
If you need model specific information we need your model number please. The information above should help you accomplish the light bulb change.
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Westinghouse Refrigerators
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
Im after a manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Nov 03, 2009 | Westinghouse Refrigerators
Refrigerators Logo
828 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
