Question about Refrigerators
We have a Viking Side by Side Model #VCSB423DSS. We have ice build up around the ice maker and frozen ice lines dripping down the back of the ice maker area. The drip pan under the refrigerator was full of water and the area under the water filter has water also. The freezer department area also has a loud noise.
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
barkencoa
  • 3463 Answers
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
Posted on Dec 20, 2008
CRTN
  • 716 Answers
SOURCE: terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Posted on Jan 05, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Whirlpool refrigerator model ed5phexnloo loud noise & ice build up.
If this unit has a ice maker, when it fills the tray, water spills out around the fill tube. The water drips down and builds up around the fan over time. Need a drain line extension to slide over water line, should take care of issue.
Aug 18, 2012 | Whirlpool Refrigerators
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model KSBS25FK side by side--the ice maker not making any ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Oct 11, 2010 | KitchenAid KSBS25FK Side by Side...
Ice maker line poped out of back and water line going to ice maker frozen
Sometimes over the winter months the tube going to the ice maker can become blocked with ice and cause this tube to pop out.
1. With the water supply going to your refrigerator on take a look at the end that popped out and see if you can see it drip at all. If it does not drip just clear the ice out of the ice maker fill tube, then replace the line that popped out and you will be good to go.
2. If you do see a drip come out of the end that popped out you will need to trace that line back to the valve its connected to and replace that valve.
Thanks for asking.
Jun 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water drips slowy into the ice maker causing it to freeze as it comes out of the water line, and then when the ice maker ask for water, it can't fill due to frozen ice at the input hose. How do I make it...
repair or, replace the the electromagnetic solenoid water valve that supplies the icemaker located on the back right corner of the refrigerator where the clear plastic supply tube enters the machine from the house water line
Sep 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
