Question about Whirlpool Duet GHW9150P Front Load Washer
Trouble f 35 - Whirlpool Duet GHW9150P Front Load Washer
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution...
Posted on Oct 12, 2010
I have no sound on my new Kogan TV // DVD
Hello Lynne Dunn,
Since you specified NO MODEL NUMBER... I selected
a FIRST AVAILABLE full function Smart TV for you...
Look at the attached page
Kogan KALED553DSMTZA User Manual Page 35
To determine what setting you should select to
TURN ON your appropriate SOUND feature...
(page 35)...
If this fails to clear up your trouble... read furtherr
to TROUBLE resolution...(click here)
Kogan KALED553DSMTZA User Manual Troubleshooting
ELSE
You might need to call CUSTOMER support
for your consumer protectios for
a NEW (defective) appliance return process
Hope this helps
Carnac the Magnificent
Sep 05, 2017 | Televison & Video
Sc 35 -02
Fusing unit upper roller thermistoe defective.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON.Keep pressed the Utility key when appear Trouble reset message on screen.Reset and turn OFF the copier.Wait 1 minute and turn ON.
Dec 07, 2013 | Konica Minolta Konica Bizhub Pro 920 Toner...
TROUBLE CODE P1870 FOR 2000 PONTIAC FIREBIRD 3.6L
Trouble Code: P1870
Transaxle Component Slipping (4T60-E)
Trouble Code Conditions: DTC P0502, P0503, P0740, P0753, P0758, P0785 and P1860 not set, engine started, vehicle driven to a speed of 30-82 at an engine speed of 1000-3000 rpm, Fuel Shutoff inactive, TP angle from 8-35%, commanded gear not in 1st gear and the gear range is D4, TF
Nov 28, 2012 | 2000 Pontiac Firebird
Trouble code 35 chevrolet cruze
please advise what about the code 35 of chevrolet cruze 2010
Oct 14, 2012 | Chevrolet Cruze Cars & Trucks
I have a 1993 Chevy Silverado 1500. trouble codes 22, 35, & 37. what do they mean?
code 22 throttle position sensor low voltage
code 35 EGR
code 37 doesnt exist but im getting a code 37 also
Nov 08, 2011 | 1993 Chevrolet K1500
What do the trouble codes 33, 35, & 5 mean for a 1992 Dodge Spirit?
Code 5 = Battery Low Voltage
Code 33 = Air Injection Reactor Switch Solenoid
Code 35 = Idle Switch Open
Nov 18, 2010 | Dodge Spirit Cars & Trucks
Trouble codes for 1993 Dodge Daytona with 3.0 liter
CODE 12
Trouble Code 12 is a special case code that is not logged into the ECM's Non-Volatile Memory (NVM) when detected. When the ignition is "ON" and the ECM detects no ignition reference pulses coming from the ignition module, it illuminates the Service Engine Soon lamp.
CODE 22
Trouble Code 22 indicates that the Throttle Position Sensor (TPS) is reading abnormally low. TPS volts should be close to 0.42 V at closed throttle and rise smoothly in about 0.02 volt increments to a maximum reading of about 4.85 volts at WOT
CODE 35
Trouble Code 35 is not used in the Turbo cars. If this code appears while a computer is connected to the ALDL connector, it is probably the result of a bad cable connection at the PC or the ALDL connector. Reseat the cable connections.
Aug 24, 2008 | 1993 Dodge Daytona
Ribbon supply
This ribbon fits many different typewriters 25 and 35 are the same. Spool should be the metal type not the plastic, and you need the nuts on the top....
Mar 20, 2008 | Olivetti Lettera 35 L Typewriter
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
