Question about Sony DAV-HDX678WF Theater System
The s-air unit seems to be running into interferance of some kind causing the sound to go in and out in my rear speakers. I've heard that Sony has an adapter that I can get to fix the problem after going through roughly two hours of trouble shooting with someone who is reading a scripted manual. Does anyone have any suggestions? And yes, I've already upgraded all of my HDMI cables and tried foil on the signal transmitter on the back of the main unit.
  • 3,083 Answers
I found a web blog that might explain the problem you're having, in case you're running wireless broadband:
http://news.cnet.com/8301-17938_105-9878723-1.html
The last review on the page talks about this.
Posted on Oct 13, 2010
Random interference problem with Shure UR4D
I would need to hear it to be completely sure (does it sound a little bit like slow morse code?), but it sounds like what you're hearing is probably cell phone interference. Certain cell phones are more likely to cause it (anything with PTT capability) because of their transmitter power, but any cell phone close enough to the receiver could give you grief. If you're playing in unpredictable places, try to get the antennae well overhead of the audience, with a straight shot to the transmitters, and as close as is reasonably possible.
Mar 21, 2013 | Shure UR4D Dual Diversity UHF Wireless...
I get static interference noise
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 07, 2011 | Altec Lansing Multimedia Computer Speakers
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
I've had my my Logitech speakers for a few months now and they've worked fine up until a few weeks ago. Now if I turn the volume up more than a quarter of the way the sound goes scratchy and...
hope this helps
Jun 04, 2011 | Logitech X-540 Computer Speakers
Interferance on the speaker even when on stand by
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 06, 2011 | Bose Companion 3 Series II Multimedia...
Got issues with some kind of background noise that suddenly shows up after some minutes of use... Its some kind of a buzzing sound, that appear once a while and stays there until i turn the sound off.
There are a few things that can cause this kind of sound through your speakers. First off, your cable wire. If it's not attached to the subwoofer, remove it and try a different cable. It could be that a piece of the wiring inside the cable has been damaged. If this doesn't help, your next bet would be to check the sound card inside the computer. Try plugging in a different pair of speakers or some headphones. If you still hear the buzzing sound your sound card needs to be repaired or replaced. Finally, you could have some electrical interference caused by certain devices like a cell phone or your TV. Try turning the devices off and see if the buzzing sound is still being heard.
Dec 26, 2010 | Creative Technology Creative Inspire T3130...
Buzing noise from power unit
What kind of system is it?
What "power thing" inside what?
It's a good chance its a ground loop issue.  Make sure the power cords aren't wrapped around each other or touching the speakers or running parallel with the speaker wires for more than a couple inches (interference transmitted into the speaker lines audible through speakers).
Aug 04, 2009 | Sony DAV-SA30 System
Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Feb 16, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony DAV-HDX678WF Theater System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
