Question about Dymo ExecuLabel LM450 Thermal Label Printer
Labels put in upside down. Paper got stuck. Paper out but gears sound like they are popping when we try to feed paper. Opened case as for as we feel comfortable. Nothing visible. Any advise? Thanks, Mark (Labelwriter 400)
Check that the the spools are firmly pressed against the label roll. Click on this link below to view the Dymo LabelWriter 400 owners manual, software, and support page:
http://global.dymo.com/ieIE/Products/LabelWriter_400.html
Posted on Oct 13, 2010
There was a paper jam, we took the paper out. Now it wont feed at all
Have you tried turning it upside down and shake it in case something is fallen or jammed in it. Check carefully that there is no tiny bits of paper stuck in it.
Aug 11, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Remove platen on Swintec 8011 typewriter
I can't remember which models have which features, but some Swintecs have pop out plantens, and some don't. If it is pop out, you will find a plastic V clip in the frame of the typewriter through which the platen shaft passes on both sides of the typewriter and platen. Pay close attention to which side the gear of the platen is situated before removing to make sure you put it back on the same side of the typewriter. Squeeze the V clips and pull the platen up and out. When re-installing, make sure the metal paper table is in correctly by aligning the fingers on each side into their mounting guides, or you will have paper jams, paper feed trouble, and other issues. You can clean the labels out with something that will not leave an oily residue on the paper table, paper feed rollers, or the platen. Re-install the platen by aligning the V clips to the frame on each side, and press them down until they snap into place.
Mar 23, 2009 | Office Equipment & Supplies
HP C5280 Paper feed not working
Turn it upside down to see if there is anything stuck in it. Open the lid and look inside to see if anything is stuck or loose, such as cartridges not sitting correctly.
Aug 28, 2008 | Office Equipment & Supplies
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Canon MP160 all in one
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jun 12, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Dymo ExecuLabel LM450 Thermal Label Printer Logo
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
