Question about Aastra Telecom Powertouch/Vista 390 Corded Phone
I have replaced my old Vista 350 with a Vista 390. There are no indicators on the screen beside soft keys as I had on the 350 & there is no information in the booklet regarding soft keys. I now have a message waiting but do not know how to access it.
Touchpad not workin at all
u can turn on or turn off the touchpad functionality of ur notebook..what must have happened is u would have turned off the touchpad of ur notebook by mistake & now u dont know how to turn it on....The key to turn on the touchpad can be different on different notebooks...so it would have been easier for me to provide u a resolution if u would have also mentioned the model of ur notebook... Generally there is a small button just beside the touchpad which is used to turn or off the tochpad, if the small button is amber in color then the touchpad is turned off & if its blue in color then touchpad is on...otherwise sometimes there is no button beside the touchpad & then there is a key combination to turn on or off the touchpad & it is Fn+F7....
try this out, it might work for u, if it works then let me know by rating this solution...
Jul 10, 2010 | Microsoft Windows Vista Home Premium with...
Voice mail
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Apr 27, 2010 | NorStar T7316E Telephone
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Acer 5920 vista page fault in a non paged a blue warrning page
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. If again that's blue error screen come then remove the RAM, clean it by soft napkin, Fix it back on ram slot & on power button. If nothing changes then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Jan 10, 2010 | Acer Aspire 5920-6574 Notebook
Yesterday, when trying to send and receive email, i got the message "The remote party has ended this connection." Then today, screen started to freeze on text messages. Then finally, phone can't get...
It seems software problem.Try again reseting the device like that
You can reset your device’s settings and clear all added
data from memory.
Resetting the device
1. On the Home screen, press the Start soft key.
2. Select Settings → More... → Security → More... →
Reset.
3. Enter the reset password and press the Done soft key.
The default password is “0000.”
4. Press the Yes soft key to confirm the reset.
5. Press the Yes soft key to confirm deleting DRM files.
The device resets and reboots itself.
Jan 08, 2010 | Samsung Blackjack SGH-I607 Smartphone
Screen going blank.switches off.
steps to copy phone to sim
- press down soft key once
- then press up key two times & select button
- then again press up once & select button
- then press down key 5 times & then select 3 times
- wait for 2-5 mins your phone contacts will be copied to sim
vote me if u get this
Jan 04, 2010 | Sony Ericsson K850i Mobile Phone
How do I get a number off my reject call list?
hello my friend, here's the steps to remove a number from the reject list.
To delete entries from the Reject List follow the steps below:
  1. From the standby screen, press the right soft key for Menu
  2. Select Address Book (8)
  3. Select Reject List (5)
  4. Highlight the desired entry, using the navigation keys
  5. Press the left soft key for Options
  6. Select Remove (3)
  7. Choose Selected (1)
  8. Press the left soft key for Yes to confirm the deletion of the Reject List entry
To delete All entries from the Reject List follow the steps below:
  4. Highlight any of the entries, using the navigation keys
  7. Select All (2)
  8. Press the left soft key for Yes to confirm the deletion of All Reject List entries
Hope that'll help you in some way.
Happy Holidays...
**Please rate my post and/or leave a comment** ...Thanks...
Dec 21, 2009 | Samsung Magnet SGH-a257 Cell Phone
V3i switch right and left soft keys
change feature icons & home keys
Change feature icons, soft key labels, and
smart key function in the home screen:
- > Settings > Personalize > Home Screen
> Home Keys
Oct 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Voicemail MSG indicator, but no message
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s theat left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Sep 10, 2009 | NorStar M7310 Corded Phone
THE DISK THAT CAME WITH MY PANTECH DUO IS NOT COMPATIBLE WITH WINDOWS VISTA AND I CAN NOT SET UP MY PHONE
try this:
make sure Modem Link on the phone is set to Inactive by going to:
At the Home screen, press the left soft key to go into the Start menu.
  • Click on Settings.
  • Click on Connections.
  • Click on Modem Link.
  • If it is set to Active, press the control pad left or right to select Inactive, and press the left soft key Done.
However, if the Modem Link is was already set to inactive. Do the following:
  • At the Home screen, press the left soft key to go into the Start menu.
  • Click on USB to PC.
  • Make sure Enable advanced network functionality is not checked. Then press the left soft key, Done.
After performing this step the phone should connect to your computer via usb and Vista should successfully detected it and you should be able to copy files over and get it set up.
Dec 13, 2008 | Pantech Duo Smartphone
Aastra Telecom Powertouch/Vista 390 Corded Phone Logo
188 people viewed this question
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
Jose Ma DM.
Jose Ma DM.
Michel Laprise Sr
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
