Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have a sharp aquos lc42d62u that has sound but no picture. how can i get the picture back?
  • Sharp Master
  • 5,159 Answers
It depends on what is wrong. It's usually a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Oct 13, 2010
How to connect pc to sharp lc42d62u tv
Download its user manual by internet. It has all details.
Dec 16, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I HAVE SOUND IN MY LC42D62U NO PICTURE
I had a TV guy to come and hang my Sharp LC-65SE94U I bought it in March 2009. The TV guy broke it. How much is my tv worth? Thank you for your time. pammie10@comcast.net
Jul 11, 2012 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Need a base for LC-42D62U
http://www.partstore.com/Model/Sharp/Sharp/LC42D62U.aspx?SearchTerm=True
You will require the Stand, the screws for the Stand, and the Stand base assembly.
Mar 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, but have audio
There is a few possibilities why it has no picture most common for LC42D62U is that one of the cables that connects main unit to the LCD control unit not sitting properly in it's receptacle, gentle push that's all it needs.
Nov 01, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sharp Aquos LC42D62U for a little over a year and it has a vertical line in the middle of the screen.
panel is bad. repair around 90% of what you paid for it. if in warranty repair is free. I would not suggest to fix. not very economical panel around 700-800 plus labor.hope this helps
Jun 04, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Flashing greenpowere light set not comming on sharplcd lc42d62u
Some TVs will flash an error code when at fault. Could be the main power supply, could be the backlight power supply.
Nov 14, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc42d62u green blinking light
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
395 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
