Question about Karcher 2500 PSI Pressure Washer
Sudden loss of high pressure. - Karcher 2500 PSI Pressure Washer
    Scholar:
  • 100 Answers
I own a 2005buick lacrosse I was driving in snow and I was doing donuts (don't ask) now my steering wheel is extremely hard to turn, what could it be and is it easily fixable"
putting all the variables together( splashed up snow, high rpms, quick actions of the steering wheel requiring constant pump pressure and the sudden loss of power assist) I would suspect that the power steering belt is loose or missing or needs replacing
Nov 22, 2014 | 2005 Buick LaCrosse
Have a 99 Toyota camry n brake light is on after changing right front brake caliper
Master cylinder fluid piston has entered into a brake safe mode.
when the high pressure brake system is opened in any way, the brake master cylinder piston reaches to the far end of the master cylinder which trips the brake system warning light.
This brake light condition is due to sudden loss of brake fluid pressure on the right front brake caliper assembly during the replacement.
Left rear brake caliper bleed valve will ned to be "opened" until master cylinder piston travels into the opposite direction which "resets" the brake system warning light.
Dot 4 brake fluid recommened for most, but not all vehicles.
Reference vehicle to owners manual for replacement fluid is replaced under master cylinder brake system cap.
Aug 18, 2013 | 1993 Buick Park Avenue
Oil loss sudden
big oil leak? or loss of oil pressure?
Aug 03, 2011 | 2005 GMC Envoy
Sudden lose of oil pressure
mcdevito75 here, It"s possible with the mileage on the engine the oil pressure is being reduced while accelerating or comimg to a stop, or the oil pressure switch is faulty on the engine.
Jun 17, 2010 | 1991 Dodge Caravan
You are having a sudden loss of power during acceleration with your 1994 dodge ram 250 what is causing this electrical or fuel issues?
You couldn't pay me to own a dodge anything, so I am pretty sure you are mistaken about mine having a sudden loss of power.
If I did have one with those symptoms id be checking fuel pressure first.
Apr 01, 2010 | Dodge Ram 250 Cars & Trucks
Oil pressure loss
the 1st thing u do is have the oil pressure tested with a test mechanical gauge by a shop, most times it is just the oil pressure sending unit is defective, but never assume that is the problem, low oil pressure will distroy a $5000.00 engine very quickly, u can just try a new sending unit, but highly recommend a pressure test with a mechanical gauge before you run the engine anymore.
Dec 05, 2009 | 2000 Jeep Cherokee
Oil pressure really high
get the oil pressure sender and gauge checked most likley cause is incorrect reading not sudden high oil pressure
Oct 22, 2009 | 1991 GMC Sierra
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
Suzuki Vitara 2006 Poer Steering Sudden Loss
some power steering system is computer control. if you disconnect battery the control module have to be program.the control module uses vechicle speed sensor and steering wheel rotation sensor.to operate an actuator in the power steering pump to control pump pressure and steering assistance.
May 24, 2009 | 2006 Suzuki Grand Vitara
05 Golf TDI sudden loss of power. Turbo issue?
ecu problem! go and find someone with VAG-COM and get it checked for fault codes. glad i could help!
Dec 24, 2008 | 2000 Volkswagen Golf
Karcher 2500 PSI Pressure Washer Logo
59 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
