Question about Lexmark X9350 All-In-One InkJet Printer
The printer will not connect to the wireless router
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Do you have your SSID, and wireless key. Have you installed the driver for your Lexmark? In other words, Is Printer showing up in the Printer list? I don't know which version or Mac you have, So..this Link to lexmark will be very helpful; Hope this will get you connected.
http://support.lexmark.com/index?page=content&id=HO3119&locale=EN&userlocale=EN_US
Posted on Oct 12, 2010
How to connect to wireless router
Are you trying to :
1) Connect the second Wireless Router to the internet as well?
2) Connect the second Wireless Router to the existing Wireless Router which is already connected to the internet
Feb 24, 2014 | Lexmark X8350 All-in-One Plus Photo with...
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Mar 15, 2011 | Belkin (F5D5231-4) Router
Can I connect my canon mp240 printer by wireless
The Canon Pixma MP240 canot be connected to a router wirelessly. You could buy a USB printer hub which would allow you to connect your printer to a wireless router. Basically, the printer would connect to the hub over USB, the hub would connect to your router over the netowrk cable, and this would allow you to connect to the printer wirelessly.
Mar 05, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
I want to connect a wireless Cannon printer to a Toshiba laptop, do I need a certain type of router? I have WiFi and WWAN internet connection, do I still need a router?
The printer needs to be connected to a router.
The router has to be wireless.
The laptop should then be connected to the router in order to install.
The printer shoul have an option to search and connect to a wireless router. After searching an connecting, you have to connect the laptop to the router and install the printer as an network printer.
Sep 21, 2010 | Computers & Internet
Connot connect printer to wireless router
this may be due to the security password that is enabled in the router... its recommended to use WEP password in router to connect wireless devices...if you use any other encryption type like WPA/WPA2 then change it to WEP and connect it....if it is a belkin router then you need to disable the WiFi protected setup too.......
Apr 18, 2010 | Brother MFC-9840CDW Laser Printer
Can I connect my 2wire to my printer to print wireless, if so how?
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
on your printer there will be settings of network connection.
you just need to connect to the wireless network on the printer
Click here to know more about routers
Jan 10, 2010 | 2wire HomePortal 100W (1000-400026-000)...
Can't connect my new Brother MFC490CW wireless printer. I do I proceed to activate my printer with this router (SMC2804WBRP-G)
ti is a wireless printer.
You will need to connect to the wireless network on the printer.
you will need to check the wireless settings of the router.
Click Here to know how to check the settings of the router.
Nov 01, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Lexmark X9350 All-In-One InkJet Printer Logo
246 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
