Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
I have a older spa with a Sta Rite pump motor. Without removing the damaged pump I was able to see the model number of the pump through a mirror. I beleive it reads K48M5A3, is there any way that you can confirm this model number.
    Novelist:
  • 116 Answers
That would definitely be the model number. The K indicates Capacitor start and run, the 48 indicates the frame size, and the "M" indicates horsepower (1.5 hp, in your case). If your replacing the motor, make sure you get the same Horsepower and Service Factor ratings. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 13, 2010
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Installed new pump unit starts and runs for 15 minutes then trips breaker what should I check
When the pump nears the 15 minute mark, check the housing to determine whether it is running hot. Also listen for changes in pumping sounds as something may be causing restriction.
Nov 22, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
My 1978 Hot springs spa won't run for more that 10 mins. without the spa pump turning itself off. Its a Sta-Rite Maxi- Glass spa pump.
Thank you for posting your question here on Fixya.com.
Something is causing the pump motor to overheat and shut off to avoid permanent failure.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft to see if it is damaged, bent, or the bearings failing or seized.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced.
*All of this assumes this is an older/existing installation that has worked properly in the past and is just now showing signs of failure. If this is a new install look at your line voltage versus the voltage the motor is set to accept. If feeding 115 to a motor wired to be on 230 you will also get the situation you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Oct 30, 2010 | Sta Rite Sta - Rite Maxeglas / Duraglas...
What spa pump replaces the Sta Rite model # K48M5A3
That model number you gave is the motor model number. I can however tell you that motor is a 1.5hp motor. So if your just looking to replace the motor make sure you get a 1.5 hp, with the same service factor as the old one. If your looking to replace the whole pump, then technically any 1.5 horse pump will be fine, but there are several factors you should consider. For example if your running popups, or water features, you want a medium or high head pump. There are many different makes and models of pumps out there, so you have many choices. without knowing your application, hard to recommend a replacement. Also depending on your local, suppliers in different parts of the country will carry different equipment. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 13, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
