Question about GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 Resets After Two Seconds of Operating
The light bulbs on my JVM1650 went out. I pulled the plug and replaced the bulbs. Now the microwave resets after two seconds of operating when cooking and asks to reset time and date. Is this the same controller board issue?
  • Anonymous Jun 12, 2008
    Microwave will operate for only about 2 seconds, then stop and request that we reset the clock and date. I do this, but it does not help. The problem seems intermittent, and sometimes (but not often) works.
  • GE Master
  • 9,086 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
After replacing the magnetron, if you still have a problem with your cooktop lights, the problem is on the control board, which we repair for $39.95 for customers nationwide.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
Im still trying to figure it out. I have the same issue. The weird thing is that if i unscrew the touch pad control panel and let it hang (wires and all) it works perfectly!
Posted on Jun 07, 2008
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
Microwave resets after start
See this FixYa solution. even if your model number is different.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | GE JVM1650 1000 Watts Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
Our GE Spacemaker Microwave (Model No. JVM1650) intermittently kicks off while heating and resets itself so that we have to reenter the time and date. Is this a Magnatron failure?
Saw something like this happen when a magnetron gasket was bad and Rf energy was interfering with the control board. Could also be a connection problem in the power circuit, acting like it was unplugged momentarily. Heavy draw from the High Voltage circuit when in cook mde. Eric
Jul 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge microwave jvm1650
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.
Nov 16, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
