Question about Whirlpool ED2FHEXMS Side by Side Refrigerator
There is no water getting to the ice maker. For the last while there was too much water getting to it.
  • 4,070 Answers
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Oct 13, 2010
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
SOURCE: whirlpool ice maker
#4 hit my problem right on the head.
Posted on Apr 27, 2008
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
SOURCE: no water to ice maker
We had a problem with ice maker not making ice. After alot of concern it turned out we just needed to replace the filter.
Posted on Aug 07, 2008
Ice maker in freezer, no longer brings water into it. The water is on, but no ice is being made.
check and make sure ice maker is on and bin level low enough to request ice than check the water filter possible clog --lastly the water valve at ice maker can be iced up and or failed
Jun 15, 2016 | Refrigerators
Ice maker is not producing ice. Water dispenser is working fine. On Whirlpool Gold Model #GS6SHAXLS03
If the ice maker is not refilling with water after its last harvest that points to the=> W10408179 Water Inlet Valve. If the ice maker just sits there with ice and does not empty into the ice bucket we will need to test the 4389102 Ice Level Control
Instructions on how to test can be found HERE If you have something else happening here please let me know, Sea Breeze
If the ice maker is not refilling with water the side of the water control valve that fills the ice maker is defective and you will still get water from the dispenser. The parts I listeed above are for your GS6SHAXLS03 refrigerator.
Oct 15, 2013 | Whirlpool GS6SHAXLS Side by Side...
Why did the ice maker stopped making ice
You have two sides to the water control valve so look inside your ice maker and see if after the last ice harvest your ice maker refilled with water. If half full or empty try filling the ice maker with tap water up to the top of the the ice maker. If the ice maker dumps the ice after the water freezes then does not refill with water this will point to the WR57X10051 Dual Water Inlet Valve If the ice maker does nothing once filled with tap water will point to the WR30X10093 Ice Maker Assembly and will be better to repace. I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | GE GSS25SGMBS Side by Side Refrigerator
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | U-Line Icemaker
No water in automatic ice maker, therefore no ice cubes.
Do you get water at the front dispensor, if present? If not check the refrigerator water filter. If you have an RO system feeding filtered water to the fridge, check it's filter. Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Lastly I have had to replace the entire ice cube maker, sometimes they do fail. Replacements can be found fairly easy on the internet.
Feb 21, 2010 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker not working on a samsung rf265aabp. water to selenoid no power to selenoid.
You won't have power to the solenoid till the ice maker dumps ice and sends signal requesting water. It only last for about 7 seconds.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | Refrigerators
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Apr 07, 2009 | Whirlpool ED5VHGXM Side by Side...
Maytag bottom freezer ice maker problem of ice removal
Usually low water pressure to the fridge will cause this problem. Not getting enough water to the ice maker will cause the cubes to be too small and get jammed easier. Check to see if you are using a self piercing saddle valve on your water line. If so change it to a drill type valve. This will increase water pressure to the fridge. New ice makers will not solve the problem.
Sep 19, 2007 | Maytag MBF2256H Bottom Freezer...
Whirlpool ED2FHEXMS Side by Side Refrigerator Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
