Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Cannot get to work with manual transmission please help with any ideas?
  • Viper Master
  • 625 Answers
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Posted on Oct 14, 2010
Gearbox not working
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Aug 11, 2016 | Mitsubishi Cars & Trucks
My 2008 Honda civic 5 speed manual transmission will not go into reverse.any ideas please help
Internal trani issue most likely you need to get it checked by a transmission repair facility
Apr 20, 2015 | 2008 Honda Civic 1.8
My 1985 GMC Sierra TH350 trannys. The speedometer isn't working but will ping sometimes. I have no idea what it is so anybody please help
The gear that is in the adapter for the transmission is plastic and they would strip out, easy fix and cheap too
Feb 09, 2013 | Cars & Trucks
Whining in transmission
If the noise was not there before any work was done
recently,then you may be on to something
I would say the whining is in the trans,front input bearing
One of those things you just have to replace & see what happens
That is a home project,not one you pay someone to do
& have no idea what was done
I do all my own work, so I can learn things & control the process
I have all drive shafts checked for being straight,install or have
installed all new joints & always have them balanced
I have all flywheels & clutch assy balanced,only when it it necessary
to have things apart to start with
Sep 12, 2012 | 1992 Isuzu Rodeo
I have a 2003 mits eclipse spider. Never had any problems until now. Driving 45mph and car dies I lose all power with no gears not even reverse. Acts as if transmission went out. Towed it home drained...
it would help if i knew if it was and automatic or manual transmission. in either case most transmissions have magnets in the drain pan to keep metal particles from re entering the system. so simply removing the drain plug wont tell you much. other than that without know weather or not its and auto or manual i cant help you out. please clarify and im sure we can find a solution
Apr 13, 2012 | 2003 Mitsubishi Eclipse Spyder
2003 Odyssey. Door locks only work manually.
There must be a ground wire to frame that was disconnected. Take the vehicle back to the shop and have them look.
Feb 12, 2010 | 2003 Honda Odyssey
Need instructions on customizing Transmission Verification Report
Terry,
Please send me your email address...I can send you the Facsimile Guide in PDF formatt pages 11-11 and 11-12 provide Tx Report Settings.
tswiercinsky@yahoo.com
Jun 03, 2009 | Canon Laser Class 8500 Printer
We have a 1999 Audi A4 Quatro that has recently started acting up. It starts up but it seems that the transmission will not work correctly. You put it in gear and the RPM goes up but the car does not go....
First check the transmission fluid with the engine at an idle (for automatic transmissions) and take note that there is a cold and hot level on the dipstick. Hope this helps. Good luck
Apr 27, 2009 | Audi A4 Cars & Trucks
Hoses for Transmission
It may be a add on transmission cooler some one installed to keep the transmission fluid cool during towing or heavy mountain climbing.
Mar 29, 2009 | 1989 Jeep Cherokee
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
381 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
