Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
IN MY CRAFTSMAN TRACTOR, THE ENGINE DOES NOT STOP WHEN I GET OFF THE SEAT
    Brigadier General:
  • 3,911 Answers
If you bought it new, then you most likely need to get a new seat switch. Sears carries parts for just about everything back to when they were selling dinosaur shoes. You can check the switch with a simple ohmmeter. Weight on seat closed or open and weight off seat the other condition. If the switch works and is wired in, then you need to chase the wiring down to the central relay where all the safety switches connect. If you bought it used a prior owner could have defeated the switch as an annoyance.
Posted on Oct 13, 2010
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Every time I use the lever to get the blades started it kills the engine. it does it even after i removed the belt. what is causing the blade rotation lever to kill the engine?
hi there talane
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector then retry then check blade engagement switch may be playing up or a nuetral switch playing up but more likely a seat switch
with operator off seat and park brake on engine runs, but with pk brake off and operator off seat
engine stops , same if operator leaves seat and blades engages -engine stops,
if unit not in nuetral and pk brake not on unit wont start
take look
hope it helps
cheers pauly46
Jul 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stops after releasing the clutch!
sounds like the seat saftey switchis bad or the cluch switch is iwould start with seat switch hope this helps
Aug 13, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 42 '' 19.5hp lawn tractor gear shift will not engage. Engine and blades work fine but cannot put tractor in gear.
the belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
16 hp craftsman mower will not run when I release the brake?
does the engine run until you release the brake? if so look at the seat switch it is supposed to kill the engine if you get off with the mower in gear.
Jul 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Starting Craftsman model 917.270430 riding mower.
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''
flop the seat forward, push the connector firmly onto the seat switch [in the middle of the seat underside], should solve your problem, or the switch could be bad, but not likely unless you're 300lbs
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
