Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1185 cartridge error msg
1. keep getting error msg that cartridge is installed wrong, but i had not changed them. have since removed and re-installed the same cartridges, yet still get msg every time i try to print.
2. have tried powering off printer, that did not solve error msg.
3. power light on printer flashes when turned on.
4. print queue has job that i was able to change the status from paused to cancel...but cannot delete it.
  • Anonymous Jan 23, 2009
    Same problem - printer stopped in the middle of printing a page and said cartridges were installed wrong - kept prompting me to turn off, open printer, turn on, remove cartridges, replace cartridges and try again. Doesn't solve problem.
  • 304 Answers
Step 1). Try cleaning the gold contacts on the print cartridge and on the printer itself with a pen eraser and a little alcohol.
Step 2). Uninstall the printer software and reinstall it.
Step 3). If the above two steps fail try a new cartridge. If none of these solutions work there is an electronic problem with the printer and it will have to be professionally diagnosed or replaced.
Hope this was of some help to you.
George
Posted on Jul 17, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
Hola soy luis tengo una lexmark x1185 y compre cartuchos nuevos y el ***** no me lo reconoce compre otro y tambien no lo reconoce queria saber que debo hachacer para que pueda funcionar
Posted on Jul 26, 2012
My Lexmark Z2300 is giving me an error msg that the cartridge is in compatible. The cartridge is actually a Lexmark 14. Once I took the cartridge out and powered off, then powered back on and added th
were they 'refilled' cartridges ? Lexmarks are sensitive to that...they have a chip in their tanks that you have to change/reset....you can't just refill them with ink.
Tallon41
Sep 06, 2012 | Lexmark Z2300 InkJet Printer
I keep getting a msg saying carterage error on my printer
If you DID NOT use a HP cartridge you get the error message.
If you did use a HP cartridge. Unplug the printer. Wait 2 minutes.
Plug in the printer. If same error message. Remove cartridge and reinstall. Make sure no clear tape is left on cartridge contact face.
Jul 11, 2012 | HP Officejet 4355 All-In-One InkJet...
Hi need to know how to open my printer and get to where i need to put the new cartridges in it i have a lexmark x1185 please help me
The entire top of your printer lifts up. (Scanner unit.)
Refer to this setup guide:
Lexmark X1100 Series Setup Guide
See steps 6 through 9.
Once the lid is lifted, there are locking tabs on each cartridge. Squeeze and lift up. You can then lift up and out on the cartridges. Reverse the procedure to install the new cartridges.
NOTE: Make sure the printer is ON during cartridge removal and replacement.
Thanks for using Fixya.
Nov 05, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
How to refill my ink cartridges on my lexmark x1185 printer/scanner.
Here are links for refill instructions:
http://www.refillinstructions.com/Lexmark/L1.htm
http://www.refillinstructions.com/Lexmark/L2.htm
A few tips: make sure that you do not insert air in the syringe along with the ink, because you will get poor print quality (I am telling you that because I don't know if you have the refill clip that removes the excess air). Pour the ink slowly and if it starts leaking (either from the refill hole or the print head), just remove 1 or 2ml. of ink. Wipe the electric contacts gently with some tissue and put the cartridges back in the printer and print.
Here are 2 videos too, it will make it easier for you if you watch them.
Oct 03, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
No installtion disc for Lexmark X1185 and it is not listed
Use the following link to download the driver for the Lexmark X1185 printer
http://www.siliconguide.com/drivers/device/85/
Sep 03, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Clogged print head
Please click on this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:435:0:0&framed=&docid=ENUS18888&relevance=1
Even after cleaning you get the same results you need to contact lexmark and get the cartridge changed as the cart comes with 6 months warranty ...good luck...
Jul 16, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
216 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
