Question about Faberware 12-55 Cup Coffee Urn
How much coffee do I use for the 22-cup Farberware Coffeemaker?
SOURCE: Farberware model fsu255
check out kitchenmanuals.com and search for FSU255 and select coffee makers. you will see the manual there. open and do a file save as...good luck
Posted on Apr 30, 2008
  • 59 Answers
SOURCE: How much coffee grounds for a 22 cup west bend
We use 2 1/4 cups for a full 36 cups. A fraction under 1 1/2 cups is good for 22 cups.
Posted on Nov 27, 2009
Richie_asg1
  • 1036 Answers
SOURCE: My Keurig coffeemaker shuts itself off, sometimes
This is a heating problem.
What usually happens when heating elements start to go, is that they get thinner. This means that the same energy goes through a thinner wire - so it actually gets hotter than it should (like a fuse).
There will be an over-temperature switch that will cut out (to prevent a fire or damage) - so this is tripping off.
Replace the element with a factory original - and try again.
Check for any blackened connections at the element.
Posted on Mar 04, 2010
  • 176 Answers
SOURCE: Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Posted on Jul 27, 2010
  • 176 Answers
SOURCE: Lost the users manual for the Farberware 155 Automatic Perculator
Hi. 3 scoops of coffee to 3 cups, Them adjust from there, bobbyone
Posted on Aug 11, 2010
What store can I find a glass carafe for a farberware 12 cup coffee maker?
They have them at Walmart. Has two tops to assure fit to Faberware. It is a universal fit. Thepartsbiz.com GL312_ME# Universal Replacement Millennium Style 12 Cup Coffee Carafe GL312
Oct 10, 2014 | Farberware Coffee Makers & Espresso...
I have an 18-55 cup farberware stainless steel coffe urn. I loaned it to a friend and the manual is now missing which includes the directions for making the coffee for the various cup levels. Can you...
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee makers try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FiXYa!
Aug 08, 2011 | Farberware Coffee Urn 1255 cup Coffee...
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
I have farberware 56 cup coffee maker w. no instructions. How much coffee do I add to coffee maker for each cup?
I heaped teaspoon for every person + one for the pot
very simple to remember.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Farberware 155C Urn coffee maker, light is on when plugged in
Hi. There are a few things that can be broken. Take the bottom off and see if you can find the problem. Good luck bobbyone
Jan 01, 2010 | Faberware 10-22 Cup Coffee Urn
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Faberware 12-55 Cup Coffee Urn Logo
169 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
