Ford taurus has clicking but won't start engine has new battery
  • 2,229 Answers
A clicking sound when you try to start the engine is usually caused by the starter solenoid not getting enough power to start the engine--in fact, it doesn't even have enough power to engage the bendix with the starter.
You say you have a new battery--are the terminals clean (and the cables)?
Also, check the ground where it is fastened to the engine.
Posted on Oct 12, 2010
2006 Ford taurus won't start, starter, altlernator, battery replaced, ignition starter switch, neutral safely switch changed, still nothing
I looked at info for your security system, it is starter motor disable. I didn't see 06 ford Taurus in my database, so I looked at 05.
Battery has a full charge and battery connections all good?
We can usually do some tests to see if starter motor will crank the engine, but, if the security is the problem, it still won't start.
You can check for applicable trouble codes? Try a different key?
Feb 16, 2018 | 2006 Ford Taurus
My ford Taurus won't start, I replaced the battery and now the anti theft system kills the engine
replacing battery more likely erase ECM memory.best to start vechicle let enginet idle until ECM relearn memory.your vechicle has to complete full drive cycle before ECM MEMORY return if not let dealership reset engine idle.
Jan 13, 2013 | 2001 Ford Taurus
2001 ford taurus power draining new battery & new alternater won't work when cables are removed from battery
That suggests that the problem is in the harness, something in the connector or wiring is causing an open circuit. You will need to have the circuit tested to find the fault. Ford alternators have known connector issues & new aftermarket connectors are readily available at most auto parts stores.
Oct 25, 2017 | 2001 Ford Taurus
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Sep 22, 2012 | 2000 Ford Taurus
Car won't start. Gages bounce quickly & make a clicking sound on 2006 ford taurus
check your battery,or not clean battery terminals,or starter motor solenoid.
Aug 22, 2012 | 1993 Cadillac DeVille
1998tarus starts when engine is cold, won't restart when engine is warm, nothing, no clicking
sounds like either the starter solenoid is dying or a bad connection at the battery
Jan 28, 2012 | 1998 Ford Taurus
My 2000 ford taurus won't start,
The click under dash is just a relay. sounds like starter solenoid quit working.
Dec 27, 2011 | 2000 Ford Taurus
2002 ford taurus won't start - brand new battery and complete tune up still won't start
Sounds like your not getting any fuel..Listen for the fuel pump,by removing gas cap and put your ear up to it..cycle the key without starting it and listen for the pump..sometimes you can beat on the bottom of the tank and it will jarr the pump and it will start running again..Not a fix but a conformation
Sep 08, 2011 | 2002 Ford Taurus
My ford taurus won't start put on new starter and new batterie
New starter and batttery means that the engine must crank well but if the FUEL and SPARK settings are not correct or faulty then the engine will not start.
So please have the fuel checked, from the fuel filter , pump and pressure of fuel.
Check for the spark intensity and timing. If any of the above is absent or is not to the level desired then it must be checked.
Jul 12, 2011 | 1999 Ford Taurus
My ford taurus doesnt turn on. Lights, stereo dashboard lights all turn on except the engine it sounds like it wants to turn on but it doesnt I dont know what can be wrong with the car??
If the starter is clicking, or the engine is turning over slowly, try replacing the battery or try getting a jump to see if you can get the engine to start.
If the engine is turning over, but won't start, it sounds like you may have a bad timing belt or your timing tensioner or idler has gone out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 17, 2011 | 1994 Ford Taurus
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
