Question about Faberware 12-55 Cup Coffee Urn
How much coffee do I use for the 22-cup Farberware coffee pot?
    Master:
  • 504 Answers
That would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Posted on Mar 08, 2017
SOURCE: 8-cup Farberware electric coffee maker
Farberware was bought by a Chinese company and isn't the Farberware your mother used any more. This coffee pot problem is epidemic with no suppor, it is Not a spring problem 99% of the time.. There is a thermostat that controls the electric flow underneath to the heater. Apparantly this is the most likely culprit. Not sure yet where to get another one. It is easily changed with a Phillips Screwdriver. It shouldn't be more than $5 so find one and give it a try. If it is supplied by the manufacturer, it will most likely go again under 1 year. Buy a Newco OCS-8.
Posted on Jan 20, 2008
  • 85 Answers
SOURCE: Need to replace the glass coffee pot
i definitely know the answer to this one..... my gevalia glass pot broke one morning. I called the gevalia customer care number and the rushed me out another immediately!
wow! and I thought they would charge me.... I paid nothing! great coffee! great customer service!
Posted on Jun 06, 2009
  • 176 Answers
SOURCE: Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Posted on Jul 27, 2010
  • 176 Answers
SOURCE: Lost the users manual for the Farberware 155 Automatic Perculator
Hi. 3 scoops of coffee to 3 cups, Them adjust from there, bobbyone
Posted on Aug 11, 2010
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Oops I think I put my solution in the wrong place.
Here's what I did.
I had this problem and tried 3 different coffee makers, used bottled water instead of water from the tap, used different coffee, and nothing solved it. UNTIL, I tried keeping my coffee in the freezer. Viola, problem solved. I was using Dunkin Donuts coffee and, it seems that sometimes it just foams up too much and causes the overflow. I don't know why freezing the grounds works, but it does and, to me, it did not diminish the flavor, at all.
Posted on Aug 29, 2010
I just purchased, what seems to be in very new condition, a 55 cup Farberware electric pot. It did not come with directions. I would think a 1lb can of coffee in the basket? There must be a fill line...
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee urns try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Jul 23, 2011 | Faberware 12-55 Cup Coffee Urn
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
I have farberware 56 cup coffee maker w. no instructions. How much coffee do I add to coffee maker for each cup?
I heaped teaspoon for every person + one for the pot
very simple to remember.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Am looking for an instruction manual for a Faberware 10 cup coffee maker
Hi, Farberware only makes 4-8-12 cup coffee pots and they all use the same manual. I have some. contact me through callahanronald@att.net. Ron
Jan 29, 2010 | Faberware (R) - Black - Ten cup capacity...
Looking for Farberware Model 142B 12 cup coffee maker paper filters and manual
Hi.For filters go to eBay and search for Farberware coffee pot parts. For manual email callahanronald@att.net. Good luck Ron
Jan 13, 2010 | Faberware FCP412 12-Cup Coffee Maker
Looking for a replacement handle for a FCP412
Go to my eBay auction. look for Farberware coffee pot parts. They are use but you cannot buy a new one (Ron622c) Good luck. bobbyone
Dec 26, 2009 | Faberware FCP412 Coffee Maker
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
Faberware 12-55 Cup Coffee Urn Logo
138 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
