Question about Panasonic PT-51HX42 51" Rear Projection Television
Panasonic cinemavision hdtv model# pt47wx42F red light blinks 3 times, have to unplug to turn set off. Need error codes,where to get parts,parts no#,and instructions to repair tv. thanks alot for any help. mark
Slinteriors
  • 8617 Answers
SOURCE: our panasonic HDTV-model #PT47WX42F all of a
You can repair that issue by installing a convergence repair kit. You can get the repair kit for your model which has the parts and detailed instructions at the following link listed under the Panasonoc repair kits. www.tvrepairworld.com
Posted on Aug 29, 2009
Testimonial: "Thanks so much for the infor-I ordered the kit and am looking forward to receiving it and fixing this problem!"
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Posted on Mar 25, 2008
ladywinn
  • 5138 Answers
SOURCE: helpme
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
Posted on Dec 27, 2008
smarthome2
  • 1114 Answers
SOURCE: Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Posted on Jul 07, 2009
asnowman
  • 788 Answers
SOURCE: TV won't turn on
If the led is blinking one time there is a problem in the 140 volt circuit. Most likely a shorted Horizontal Output Transistor or a bad flyback transformer.
I would recommend that you contact a local servicer in your area and see if they can come to your house and diagnose the problem and give you an esimate for the repair. This can be tricky to diagnose and the potential for electrical shock is very high. So I would be careful if you wish to repair it yourself.
I would guess that you should be able to get a servicer to your home and repair the set for somewhere between $350.00 - $450.00 depending on the parts that are needed and the area in which you live.
I hope that this helps you with this issue. If you have any further questions, please post and I will try to help you as much as I can.
Thanks for using FixYa
asnowman
Posted on Oct 25, 2009
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My 1992 big screen panasonic cinemavision tv keep cutting off...help!
If a 1992 model a lot of the parts are no longer available at all---what is the model number of your TV?
Most of Panasonic sets the power light will if shuts off blink a specific number of blinks--a error code.
May 27, 2012 | JVC AV-27D203 27" TV
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic cinemavision TV no longer turns on. The red light indicating the power on/off blinks 3 times.
Thats the error code for failed convergence. You can get the convergence repair kit for your model at www.tvrepairworld.com which contains the parts and the CD with repair instructions.
Sep 29, 2010 | Panasonic PT-47WX49 47" Rear Projection...
When i turn my tv the screen is bkack and the red light is on
POWER LIGHT SHOULD BLINK A ERROR CODE: 3 BLINKS REPEATED OVER AND OVER OR 5 BLINKS.
UNPLUG SET AND PLUG IT BACK AND TURN IT ON AND COUNT FOR BLINKS.
LET ME KNOW WHAT YOU FIND, I KNOW THESE SETS WELL.
sd tech
Aug 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My pt47wx42f model panasonic tv attempts to turn but fails
Thats the error code for the convergence. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and detailed instructions on how to install the kit.
Aug 08, 2009 | Televison & Video
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Mar 25, 2008 | Televison & Video
Panasonic PT-51HX42 51" Rear Projection Television Logo
606 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
