Question about Versace Gianni Madison - Men's Stainless Steel Black Dial Chronograph
How can i remove a link from ss gianni versace watch band
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
Had battery changed on my Gianni Versace 5 medallion medusa head watch but it's still not working. Help
Please Contact aftersale@carmenco.com with model number of your warch also image of your watch
Sep 30, 2016 | Versace Watches
My watch has stopped working. is it battery operated?
I could not find your model on their web site but looking at the ones they had there, if it says "automatic" on the face then it is spring driven and absence of "automatic" seems to mean it is battery driven.
I hope this helps.
Aug 14, 2010 | Versace Gianni Atelier Chronograph
Versace watch ( wristband)
Same place where you bought the watch, mate, same place where you bought the watch. Surely the watch is a Versage but the wrist band can be any band you can find at any good watchmaker of jeweller. ;)
Sep 23, 2009 | Versace 27473-008-00 Wrist Watch
Versace flc99d001s099
good after noon,to set the time and is depend on the model of your watch,if your watch is analog use the crown to set the time and date just pull the crown slowly and wind it,but if your watch is digital use the button to set the time,thank you !....
Aug 29, 2008 | Versace Gianni Atelier Chronograph
Just need the original replacement watch band
what kind of watch that you want to replace the band?
Aug 24, 2008 | Timex Watches
Adjusting the chronograph
good after noon!use the crown and the button of chronografh watch to set the time and date,thank you ! god bless!.....
Nov 14, 2007 | Versace Gianni Atelier Chronograph
Need links for versace cornishe all stainless model
an authorized retailer will be able to order them for you. Look up the nearest one on the website. http://www.vertime.com
Nov 20, 2006 | Versace Corniche Collection Watch
Versace watch
Sep 22, 2006 | Versace 27473-008-00 Wrist Watch
Versace Gianni Madison - Men's Stainless Steel Black Dial Chronograph Logo
168 people viewed this question
Top Versace Watches Experts
Jimmy Accardi
Are you a Versace Watch Expert? Answer questions, earn points and help others
