Question about Whirlpool Dishwashers
I have a Whirlpool GU1100 built-in diswasher that will not clear the pot & pans selection. It is stuck with the pots & pans and the cancel buttons lit and blinking. It will not start or clear. I have tryed to shut the power off for awhile and this has not helped. Other buttons can be pushed and will light but the other two remain blinking. If the clear button is pushed it will clear the other button but not the pots & pans or itself. Is this a problem I can fix myself?
yalmer
  • 549 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
SOURCE: Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Posted on Feb 04, 2009
  • 70 Answers
SOURCE: remains on Gentle/China mode
unplug the unit from power and plug it in back after may be minute or so.if it works, fine otherwise control panel has to be chgd.it comes as complete assly(top black part) and it is very easy to chg.
Posted on Aug 18, 2009
SOURCE: my whirpool quiet wash plus will not completey drain
lets see here you want at least ten bucks to just help me w/ my diswasher problem but if gee i figured it out all by myself i get squat thanks but no thanks.
Posted on Aug 29, 2009
  • 10 Answers
SOURCE: pots and pans light, quick
Try to pull the fuse or turn off the breaker for 30 seconds. This should reset the electronics and possibly fix the problem.
Posted on Sep 08, 2010
RESET DU1345XTVB
Try to turn the mains power off and on. If this makes no difference then try the hard reset by pressing POTS/ PANs and Heated Dry button consequitively for about 10 secs. All lights should turn on. Then cancel and see if there is any difference.
Apr 13, 2014 | Whirlpool 24 in. DU1050SS Built-in...
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Pots and pans light, quick rinse and cancel buttons all blinking. unit will not start.
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Ultra Wash Diswasher & light is flashing on pot & pans and can't remove it. Try canceling it several times
Try unplugging the dishwasher from the power for 15 minutes. This might clear the problem. If it comes back when you plug the unit back in it might be a problem with the control panel or the board.
Sep 22, 2009 | Kenmore Dishwashers
My whirpool quiet wash plus will not completey drain
Aug 28, 2009 | Dishwashers
Do not get a cold water wash from front load fridgidaire only hot
most diswashers only hook from the left side under the sink which is hot, some dishwashers on hot make the water extra hot with the bottom element for pots and pans, sounds like your dishwasher is working properly, you need hot water to sterilize. Rob
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
