Question about Kenmore 67082 Electric Dryer
Gas turns on ....link and ducts clean....gas only goes on for few seconds then turns off and few seconds later turns on again for short while...hummm
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
I have a whirlpool sixth sense tumble dryer - when I switch it on it only goes on for a few seconds and then stops again. The time remaining indicator just runs Ina little square but doesn't show a time...
does it stop right after u relase or take ur hand off the push start button? ( bad push start button) does it turn off after a while then look at ur thermostats and ur venting and duct system/. Also heating element may have short in it causing it to turn off can check that will multimeter
Dec 27, 2014 | Dryers
Kenmore 110.70982990 front loading gas dryer. Everything seems to work, except the flame stays on for only 5-10 seconds, and therefore does not produce enough heat. Lights up again after a few minutes,...
Remove the exhaust vent from the rear and try a load of laundry.
If ir dries correctly,clean and or repair the connecting exhaust vent.
It may also be necessary to disassemble the dryer and clean internal ducts.
Feb 20, 2011 | Kenmore 63942 Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Clothes dryer burner does not stay lit. At startup stays on for 30 seconds goes off for 25 seconds then subsequently stays on for 18 seconds.
your lint duct is in need of cleaning. first unplug next turn off gas , remove duct clamp,duct must not have more than a inkpin in thickness inside duct.tools needed,paper mask, screwdriver, vac foil tape. remove ductclamp pick pull brush and vac all of the lint, in duct and rear panel of dryer. duct must be as lineal as possible with no screws or crimps nor tears. karl
Oct 31, 2009 | Kenmore Dryers
My kenmore model 70 wont heat. I replaced the coils, and gas sensor. the unit has been thoroughly cleaned. the igniter is heating up, the gas will light, then goes out a few seconds later. the unit is a...
Hi, Make sure the 4" vent is clean al the way outside. Make sure the vent hood in the wall is open. It sounds like the heat is short cycling do to poor air flow.
If the vent does not appear to be an issue, Watch the ignition while running and see if the ignitor glows later in the cycle and shuts down before the flame ignites. If this happens, you will need to change the coils on top of the gas valve. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | Kenmore 63942 Dryer
My kenmore dryer will start and run when cold after it heats up the flame (gas dryer)goes out then after 3 or 4 mins. i can see the igniter light but will not start a flame after 5 or 6 seconds the igniter...
gas valve coulkd be bad if not opening after a certain period of time the ignitor will turn off and attempt a few times more,does it have a soilenoid valve also open and clean any carbon that might be built up over yrs
Jun 21, 2009 | Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Duct fan comes in, igniter lights, but no flame
Remove the front panel. Tape the door switch to the closed position. If the thermostat is calling for heat the furnace should do the following: a light on the circuit board will flash and then the exhaust blower will start. A few seconds later (10-15) you should hear clicking at at the circuit board and an orange glow should be seen thru the small viewing port. A few seconds later the gas valve should open and the orange light will turn blue. If the blue flame only lasts a few seconds and then goes out, their may either be a blockage not allowing the flame to travel to all the burners and not allowing a flame sensor to sence flame, shutting down the unit. After a few cycles of not starting, the circuit board will flash a series of codes that you can read if you look on the back of the front cover. It will give you a starting point where we can research and come up witha more difinitive answer. Let us know what you find for codes.
Oct 26, 2007 | Goodman GMS90703BXA Heater
Kenmore 67082 Electric Dryer Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
