Question about Kenmore 500 6952 Dryer
Dryer is newer and we just bought it from someone and get it home to hook it up and it the dryer wont heat up.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 13, 2010
Would the power cord installation have anything to do with whether the dryer has heat?
it has no heat because the heater is not working and was the reason it was sold
it may be a faulty heater element or switch but the cord has nothing to do with it.
May 20, 2015 | Dryers
Whirlpool
I think your old plug is probably 120 and you may need to convert to 220. It's probably the wiring is probably 220 in new home? Or maybe not grounded properly. This is a job for a professional. If you think you know what you doing, we try to save a few dollars by doing it ourselves. But sometimes it is time to call the experts, before we cause more damage and cost us more money. Good luck!
Aug 27, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Dryer IED4400SQ0 wont get hot
Did you pull the element out and test it? I think it is your heating element. Visually inspecting is never enough. Just hook it up to high voltage independently to ensure it heats. It will turn red hot.
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
Dryer wont shut off unless turned off and dryer just tumbles with no heat.
If it won't turn off or heat then it is probably the timer or if it is a newer unit the control board.
Aug 06, 2011 | Kenmore Dryers
Dryer wont start
most of these dryers have a thermal fuse that shuts the dryer down when it over heats and it is not resetable. most of these on a kenmore are on the back of the dryer. locate the thermal fuse and use an ohm meter to tell if it has continuity or not. no continuity - replace it.
also if your dryer is over heating one of the most common causes is a crimped vent hose or pipe. don't use plastic hose as it crimps shut easily and won't let the heat out of the dryer causing the problem you described.
May 25, 2010 | Kenmore 500 6952 Dryer
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
I need help hooking up my Maytag Dryer
here's a link you can try that explains both the 3 and 4 prong dryer cord configurations.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If this is an older home that already has a 3-prong receptacle installed, you can still use a 3-prong cord. However, if this a newer home, or if you plan on relocating the appliance, or making any repairs to the existing receptacle, you need to use the 4-prong. I hope this helps you.
If you weren't talking about the dryer cord configuration and need assistance with something else, please let me know.
Jan 09, 2009 | Dryers
Conveyor dryer wiring
Newer electrical codes call for a 4 wire receptacle. never splice appliance cords, it isn't woth the safety issue and they are not very expensive. you need to access the terminal block, which is where the cord goes into the dryer. the cord you use (3 or 4 wire) will depend on what is on your wall. if you wall has a 3 wire plug then you will need to connect the green wire from the center terminal to the frame of the dryer. there is probably a hole and screw next to terminal block. that is where the green wire goes on a 3 wire hook-up. if you have a 4 wire receptacle then the green wire should be hooked to center terminal (white). you will have to obtain the proper cord (pigtail) from a parts supplier.
J
Jun 10, 2008 | Dryers
2 dryers that run but have no heat
It sounds like the gas supply is not giving you any gas, as both have the exact same symptoms. You can see the glow coil getting red hot, then the safety shuts off after a it gets no gas. If you feel confident, shut off the valve in back coming from the wall, unscrew the line where it connects to the dryer. Turn the valve back on slowly, there should be gas pressure blow out of the line.
Dec 19, 2007 | Dryers
Kenmore 500 6952 Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
