Question about Panasonic Televison & Video
Panasonic tc32xl700 power light flashes once and the set will not turn on.
  • jparota Jun 01, 2008
    I have two identical tv's plugged into the same source. One is fine and the other has this problem. Wouldn't a problem with the exteriuor power supply cause the problem in both tvs. Can this be an internal tv issue?
    Unless I am missing something there is no reference to this issue on the panasonic support page.
  • 1,031 Answers
Check the power supply connector if for proper contact with the tv power plug
2.if times this may due to convergence issue.you can disconnect from source wait for 30 min then put it back for resetting.if the problem continues that means that projection TV has convergence problem can be serviced by replacing some ic's which can only be done by a technician
Posted on Jun 01, 2008
  • Starnley Johnwells
    Starnley Johnwells Jun 01, 2008
    change the source and see if the problem contines
    Guru:
  • 1,342 Answers
Panasonic TC-32LX700 Support Page
  • Georgia B
    Georgia B Jun 01, 2008
    I think ginko has posted the most probable worst case scenario for your problem. I was just offering the Support Page as an outlet to purchase replacement parts.
  • Panasonic Master
  • 19,396 Answers
The safety switch is turning off the tv , probably you have a short or a voltage problem.
  • Ginko
    Ginko Jun 01, 2008
    Try disconnecting tv from power for some time, so to reset your tv in the eventuality of a control problem.
    More likely is a problem with the power supply or a short inside, the tv detects there is a problem and turns itself off.
    Check your guaranty terms, and contact factory using the number provided at the end of your manual. They can indicate you a reapir shop in your area.
  • Ginko
    Ginko Jun 01, 2008
    is not the exterior power supply , it is probably the internal power board that is gone.
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
PANASONIC PT60LC14 SHUTS OFF AMBER POWER LIGHT BLINKS 1 TIME EVERY 5 SECONDS
According to service manual when the power button flashes amber once every 5
seconds there is a problem with one of the fans not turning or up to speed or related circuit on the projection assembly.
Nov 23, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Tv isnt turning on, you will hear a click then see the power light flash 6 times then the light goes off for about 10 mins then comes back on flasing again...and the cycle just continues. It did this once...
Sounds like a power supply problem. I worked for a short period for Panasonic at their USA plasma R&D / small scale manufacturing facility and learned that to "ignite" or start the plasma when turning on the set, a significant current discharge is required.
The recycling seems to indicate that the "brain" in the set realized that a plasma has not been established, and it is attempting to recharge the starting circuit. The flashing power light is probably significant and a trained technician or a service manual will probably identify this as a trouble code pointing to the problem. Sorry, I did not have any exposure to the finished product and cannot advise what the code means.
If the set is still under warranty, you should act immediately and get the problem taken care of, because it will not go away on its own, and will most likely get worse. Sorry the news is not better. Good luck!
Jan 28, 2011 | Panasonic Viera TH-42PX80U Plasma TV
2002 model Panasonic 53" projection tv. Once powe...
Probably an issue with the power supply. The repair business these days is a lost art - all they do is replace the board suspected to be bad - charge a small fortune and then also nail you for labor charges that are really unwarranted.
If you check out ebay for your set you may find someone parting out a set - if you can get a PS on the cheap I would try out that option. If ng, then just chuck it and get a newer, cheaper, warrantied set.
May 04, 2017 | Televison & Video
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Power light flashing once
Ouch...ok a one blink code could be either the P (power board) or the SC (scan board)...only a service tech call can tell you for sure. Ask around for some quotes first.
Nov 01, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
77 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
