Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
    President:
  • Black & Decker Master
  • 1,545 Answers
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
Tip
B&D GS500 Parts Manual Download
Download Black and Decker GS500 Cordless Grass Shear Parts Manual
Have you misplaced your Black and Decker GS500 Cordless Grass Shear Parts Manual?
Have you taken your Black and Decker GS500 Cordless Grass Shear apart, and can't get it back together?
Would you like a digital, searchable, pdf version of the Black and Decker GS500 Cordless Grass Shear Parts Guide?
Follow this link (& click FREE) to download a pdf version of the Black and Decker GS500 Cordless Grass Shear Parts documentation.
I hope that helps.
__________________________________
B&D GS500 Manual Download
on May 08, 2010 | Garden
The line trimmer does not cut the line i have to keep a pair of scissors to trim the string in my pocket
The trimmer guard should have a small steel blade where the line strikes the shield that keeps the line cut to the correct length. Check your shield to make sure the blade hasn't come loose. If it has, you should be able to get a replacement blade for it. If the shield has been beaten up too much, you'll have to replace the shield.
Oct 20, 2010 | Black & Decker 14" Grass Hog Xp...
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Sep 03, 2010 | Black & Decker 14" Grass Hog Xp...
Grass Shears Gear Assembly (Black & Decker brand)
My neighbor found where the washer went.....right on top of the big plastic white gear.
Aug 14, 2009 | Black & Decker Garden
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
I need a copy of the owners maual for Black n Decker. When I turn it on the blades do not move but the gears inside are moving. Therefore it screams. Thanks.
Do you use WD40 on the blades between sessions
If you have been cutting resinious branches there is more than a chance that the blades are seized together.
You could try putting the blades into a bucket of very hot soapy water (Without a power line attached or the battery removed )
Leave them to soak for a couple of hours, take them out of the water and give them a try, if they run then dry the blades off with a hair dryer and apply some oil to the surfaces.
If they donT then you have stripped the teeth on the gearbox and you may as well dump them as it will be cheaper to buy a new machine than it is to get B&D to repair it
Jun 16, 2009 | Black & Decker Black Decker 16" Hedge...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
187 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
