Question about Sanyo DP42746 42 in. Plasma Television
My mod #dp42647 blows the main fuse 120/5 amp tv will not come on is the main power board dsp-242 bp pn#7av4u20c17 rev:s2f could the board be the one to fix my problem thanks for time bill
  • wb4yph Oct 17, 2010
    do you think it is a cap/diode ? would this be oo the primary of the power xformer or farther down
    in the cir. i do not have a schematic what do you think cap or diode ? thanks for your time
    god bless
    bill murray
  • wb4yph Oct 18, 2010
    thanks for your time god bless you, bill murray
  • 10,594 Answers
As you said main fuse blows that is located on power supply board that indicates that power supply board is defective and need to be replaced to fix the issue.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 13, 2010
  • Shahid Electronics
    Shahid Electronics Oct 18, 2010
    Sorry for delayed reply, its primary side of power supply and most probably SMPS output chip is shorted out that is causing fuse blow up each time.
    Replace complete power board to fix it.
Fisher & paykel washer no power going to it
No reset button. There is a fuse it is soldered on & part of the main control board. They don't blow the fuse for no reason, so you need to be able to test & check everything to find out why the fuse blew (if it has) If you just replace the control board without checking then there is a good chance it may blow the new board as well. There will be no warranty on the board in that case. You really need to call a repair company who will test everything first.
Dec 27, 2015 | Fisher and Paykel Washing Machines
Sanyo DP42647 tv won't turn on.
sanyo LCD tvs recieve the on command from the main board so chances are the main board was also damaged
Jul 06, 2012 | Televison & Video
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
My sanyo vizon dp42647 wont turn on
Some food for thought here the power supply and part of the set:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
If the set is opened look on the power supply board for caps puffed up like these--dead giveaway.
If you have questions feel free to comment here--I am not the number one rated expert here for the last six weeks for nothing and I do this here for free.
SD TECH
Apr 18, 2012 | Sanyo DP42746 42 in. Plasma Television
RCA Projection TV : D52W27D Connector BP120 on Power Board ?
BP120 is not used in that model its simply a empty socket that board is used in other versions of the ITC222 chassis in which some use that plug . But your model doesnt use it. Check the fuse on the AC main board which is right next to where the power cord plugs into that board. If the fuse is blown its most likely the flyback and HOT which are causing the blown fuse. If the fuse is good then the deflection board will need replacement. www.tvrepairworld.com has replacement parts and circuit boards for that chassis and also free tech support is available.
Feb 23, 2012 | Televison & Video
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
Samick sga 120 amp keeps blowing fuses. Replaced all rectifier diodes and tranformer seems to be working fine. Any suggestions?
The fault may not be in the power supply area! The other area of blame is the main amp section. Suspect any of the devices on the heat sink (also any device in the power supply with an heat sink). Transistors can be tested easily with this problem. An Ohm Meter on the resistance setting, on the terminals (even in circuit) of the transistor, will act like you have touched the test probes together. Just like a piece of wire, because that's what it has become and why they blow the fuse!
May 15, 2010 | Audio Players & Recorders
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Sanyo DP42746 42 in. Plasma Television Logo
826 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
