Question about Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD
I have a tasco 3x-9x 40 f scope. there is no other id or model info that i can find on the scope. the scope appears to be mounted correctly and is vertical in the mount. the cross hairs are rotated to the right about 5 degrees. how do i straighten them to verticle? is there an adjustment or do i rotate the whole scope. also, the windage adjust screw takes what seems to me excessive force. what can i do to reduce the force required. thanks, flick
  • fguerrina Oct 13, 2010
    maybe the wd will work and i'll probably try it. rotating the scope is unacceptable. the crosshairs will no longer be in proper alignment with the adjusters. i was hoping there was a way to get in the scope or tune the cross hairs but the previous owner probably screwd it up and it's most likely ruined. i have a feeling the adjuster is probably cross threaded or something similar. flick
  • 2,100 Answers
To get the reticule straight up and down, yes, turn the whole scope till your eye sees it as level. The adj screw on the windage could be over too far, making it hard to turn, if that is the case, you will need to shim the mount. If it was on a bolt action rifle, you could mount the rifle in a box, or a vise, something to hold it steady, peek down the bore at a target 100 yards away, then bring the cross hairs to the target. Look back down the bore and make sure it didn't move. This will put you on paper at 100 yards. It might not be easy on a Winchester type rifle. Hope this helps.
Posted on Oct 14, 2010
  • 10,865 Answers
Hello. Get a can of a penetrating lubricant called WD-40. Spray a little into the windage adjustment screw and let it sit over night. Repeat as necessary. Regarding the cross hairs, yes do rotate the whole scope. J.
Posted on Oct 13, 2010
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
Manual bushnell sportview 3x-9x.32 scope
The Winchester 94 ejects the spent cartridge straight up and out of the top of thr receiver. This nesesitates mounting a scope off to the side to avoid jamming the action with a spent case hitting the scope and failing to clear the action.
Jun 29, 2012 | Bushnell Optics
Is there a lifetime warranty? What is wrong when it is starting to get cloudy?
Click here for a page on the warranty info for Tasco Rifle Scopes. The scope getting cloudy can mean moister has gotten inside and it has fogged up. Hope this Helps Fix Ya up.
Feb 07, 2011 | Tasco World Class Rifle Scope 39X 40 3030...
My 3x-9x.40 scope shoots low and to the right,what does one click on elevation and wind represent?
Most scopes of this type move the bullet impact 1/4 inch at 100 yards, or 1/4 minute of angle.
Sep 19, 2010 | Tasco 3-9x40 World Class Riflescope 30/30...
Blurred brand new tasco RF37X20 3X-7X20 scope
You have moisture inside the barrel. Remove the eyepiece and objective to air out and the-assemble after a few days. Be sure to mark which end is which!
Oct 24, 2009 | Bushnell Tasco Telescope Galaxsee 525x60mm...
Cap cover pentax 3x-9x scopes
You do not define "cap cover" as to whether it is a 'lens cap' of which the Objective Lens comes in varying sizes with the 3x9 scope depending on the model.
However, you should be able to find one in the size you need at most any Firearms supply store. I have even found a lens cap for a Leupold at a Walmart.
Barring that, go to; www.pentaxsportoptics.com, they should be able to help you in your quest.
Good luck. :)
Apr 14, 2009 | Pentax 3X - 9X 40mm Lightseeker XL Glossy...
Crosshairs are cocked to the right.
your scope has spun in the scope rings. Loosen the screws holding the scope to the rifle and turn scope until crosshairs are into position. Then tighten screws. You will need to sight in again. If it keeps moving replace scope rings.
Dec 12, 2008 | Tasco 3-9x40 World Class Riflescope 30/30...
Where to find manual or diagrams for Tasco scopes
The manual is here under "Generic Riflescopes". It is a .pdf file.
http://www.tasco.com/support.cfm
The Tasco site for Riflescopes
http://www.tasco.com/section.cfm?s=Riflescopes
Oct 21, 2007 | Tasco Golden Antler 3 - (9 x 40 mm)...
Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD Logo
141 people viewed this question
Top Tasco Optics Experts
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
