Question about Jandy AQUALINK RS TELELINK KIT
Have a Aqua link control. The pump is suppose to running but the spa keeps turning on and then off. What could be causing this?
  • 44 Answers
You may have a bad "spa side remote"When the 4 button remotes get water inside, they can send Fantom signals to the system. To test it you can unplug the remote and see if the problem goes away. Open up the outside control panel and unplug the black plug on the top of the board (which is just right of the red 4 pin connector). If that doesn't fix the problem, you may have a problem with the" Freeze protection" circuit,which turns on equipment when the temp sensor shows near freezing temps.
Posted on Oct 13, 2010
  • scorpio1fan Jun 09, 2011
    Spot on - No more ghost for me. Thank you!!
How do I fix "Filter VSP Communication Error" on my Aqua Pod
the VSP error is a code from the pump and not the controller or control system. the only way to clear this is to turn the breaker for the pump off for about 30 seconds to allow the electronics to reset.
Jul 09, 2014 | Hayward Pool Products Aqua Pod
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My spa hums for a few seconds then kicks off. No flow. lights and control display are working.
Is the shut off occuring @ the GFI? & is there an error code displayed on your topside?
If the breaker is kicking off, the best way to troubleshoot is to disconnect all components, (pumps, heater, circ, etc.) & then plug one in & turn the breaker on. repeat the process until you locate which component is tripping the breaker.. then you know whats causing the trouble
Feb 24, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy AQUALINK RS TELELINK KIT  Logo
374 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
