Question about Samsung (SP1203N) 120 GB Hard Drive
Microsoft window states "Replace or repair hard disk". Disk name is: SAMSUNG SP1203N ATA DEVICE. It said to back up my computer before trying to fix hard disk problem, BUT, my Gateway computer will not back up....it gives the message: "Backup Failure", data error, cyclic redundancy check. (0x80070017). I am contacting you from another computer. My windows is Vista. Thank you
4 Suggested Answers
  • 309 Answers
SOURCE: cyclic redundancy check
Cannot do it. It is a function built into the drive by the manufacturer. Besides, the CRC is a safety feature that helps ensure the data you THOUGHT you save is ACTUALLY the data you saved.
Posted on Jan 05, 2010
Ezrahite
  • 2632 Answers
SOURCE: i am getting the data error (cyclic redundancy
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Posted on Jan 31, 2011
    bronk50
    • 27725 Answers
    SOURCE: windows has detected a hard disk problem
    you could run the chkdsk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
    click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
    then select check now,start should schedule this task when restart
    it will only schedule on restart if its the Primary hard drive with an operating system on it
    do not do anything while the chkdsk utility is in progress any input may damage your computer
    hope it helps
    Posted on Apr 15, 2012
    Master hard disc..Message stating that Windows has detected a problem.
    Back up your files immediately to prevent information loss, and then contact the computer manufacturer to determine if you need to repair or replace the disk.
    + Start the backup process
    * Ask me again later
    If the disk fails before the next warning, you could lose all of the programs and documents on the disk.
    Immediate steps
    Because a disk failure will cause you to lose all programs, files and documents on the disk, you should back up your important information immediately. Try not to use your computer until you have repaired or replaced the hard disk.
    Dec 24, 2012 | Computers & Internet
    There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
    Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
    Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
    Is there a hard drive cable adaptor available from an old sp1203n samsung to a barracuda 7200.9
    Hello
    this type hard disk needs ATA-66; 40 core cable for data transmission, and four core supply cable [+5V - 0V - 0V - 12V] supply cable. The data cable only has to be bought, because, supply pin will be with the power supply unit. You can buy this cable from most of the electronic spare part shops, or computer spare part shops at your town. The picture of the cable is given here.
    gopakumarg43_26.jpgATA-66 [DATA CABLE]
    Aug 28, 2011 | Samsung (SP1203N) 120 GB Hard Drive
    My Samsung SP1203N makes a strange noise when connected
    This is the issue with the Hard disk. Better you take the back up of all of your data and change the hard disk. Other wise after some days or weeks the hard disk won't dictate. You'll lose the data...
    Aug 02, 2011 | Samsung (SP1203N) 120 GB Hard Drive
    Hi, I have an error message on my notebook laptop reading: 'windows detected a hard drive problem (repair or replace disk). Disk Failure Name: ST98823AS ATA, Device Volume C:\. How do I go about repairing...
    Leila, repairing a hard drive or replavcing it in a laptop is difficult due the the number of screws and bits and pices one has to remove to get to it. I suggest you take it to a computer specialist that deals with the brand of laptop near you New disk varies depending on size but average about$160.00 and min 2 hrs labor @ $90 and hour. The decision is is it cheaper to upgrade than repair?
    Please rate my help++++Thanks for using FIXYA
    Jul 31, 2010 | Seagate Momentus 5400.2 ST98823AS...
    Hard disk ST9120822AS ATA Device
    If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
    Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
    Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
    If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
    To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
    Nov 06, 2009 | Dell InspironTM 1501 Notebook
    Instructions For Fixing Hard Disk Errors:
    Reply to :- Instructions For Fixing Hard Disk ErrorsThe same problem is my window 7 is showing on my hard disk Disk Name: WDC WD2500BEVT-75ZCT2 ATA...
    I can still access to my data but my laptop hangs a lot..
    my laptop is Dell Inspiron 1525.
    Is my hard Disk got failed?
    I am very much worried...please someone help me.
    Aug 11, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
    I have a samsung sp1203N 120gig capacity, running with a new WDC WD5000AAKS-00A7B2 500GB HD ,as the primary drive on windows 7. My problem is that my samsung drive is only reading at a 31.4 GB capacity...
    On XP, it was Control Panel, Administrative Tools, Computer Management, Disk Management.
    Upgrade the 120gb to a Dynamic disk and then extend the partition, or if there's no data on it yet, delete the 32gb and create a 120gb one.
    Should not be that different under Win7. Hasn't changed much since NT4.0
    Jun 30, 2009 | Samsung (SP1203N) 120 GB Hard Drive
    Samsung (SP1203N) 120 GB Hard Drive Logo
    970 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
