Question about GE DWSR463EG Electric Dryer
It thumps on the bottom. I have tried to level it but no good. could something be stuck in the bottom of the drum?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 15, 2010
How do I stop light thumping noise?
For the fun of it I would pull the drum out of it and examin the bearing the drum rides on. Now some of these have a regular type wheel bearing type, and others have these wide plastic that the drum just rides on. But they are not that hard to take apart and put back together. Just need some practice.
Mar 07, 2016 | Amana ALG443RAW Gas Dryer
I have a Frigidaire front load dryer that makes a very load squeeky thumping sound like there is something heavy in there tumbling... also my clothes get stuck in between the drum and frame of the dryer...
Broken wheel or wheels the drum turns on. Not to difficult to fix. Both RepairClinic.com and appliancepartspros.com have videos to show u how good luck
Mar 05, 2015 | Frigidaire Dryers
LG DLE5977W THUMP DRUM WAS CRACKED-REPLACED FROM APP.PARTS.COM NEW DRUM OUT OF ROUND.SENT NEW DRUM SAME THUMP.REPLACED ONE ROLLER I SAW WAS BAD-SAME THUMP.REPLACED OTHER THREE ROLLERS-SAME THUMP.HELP
Anything is possible but I doubt 2 drums are bad. Since you replaced all the rollers and I assume you installed the drum on the rollers properly, i would look at the other drive parts. It might be a bad idler pulley and bearing. That is the small pulley that is spring loaded and puts tension on the belt. Check the complete assembly for any unusual free play that might cause a thump. Also look at the belt itself for any cracks or bumps.
Mar 02, 2015 | LG Dryers
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Bosch 500 series dryer double knock when drying even though nothing heavy in the load
Hello nachosmurf, The symptom you're describing is typically an indication of worn drum rollers, but can also be attributed to mis-alignment due to not being level/square. If you have a level, set it on top of the dryer and insure the unit is level, from side to side and back to front. If the unit is not level it can cause the cabinet to be un-square as to cause the drum to roll over the support rollers on a slight angle and manifest in the manner you've described - thump thump as the seam in the drum passes over the rollers. As I aluded to though, the rollers may in fact be worn. What is the age of the dryer and how often does it operate ? Daily ? 1-2 a week ? What are your loading habits, large loads as a rule, or as an exception ? Let me know if leveling the unit yields any results, if not you'll need to inspect the drum rollers and the drum itself which are accessed through the back, as is most everything with these dryers. Good luck. Let me know if you require any further assistance, if any of this solves your problem awesome ! Please take a moment to rate the info accordingly. Macmarkus :)
Apr 12, 2010 | Bosch Nexxt 500 Plus Dryer
Clothes dryer makes a ''thumping'' sound
One of your rollers has a flat spot in it or something stuck to it. Every time it rolls round to that spot the drum jumps over the little speed bump in the road. The wheel needs to be replaced.
Mar 11, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
GE DWSR463EG Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
