Question about Ingersoll Air Tools & Compressors
My 185 ingersoll rand tow behind compressor shuts down when I open the valve to blow out sprinkler system...why
    President:
  • Ingersoll Master
  • 1,388 Answers
I worked at a tool rental store while attending college and noticed that IR compressors would shut down for a variety of safety reasons. Most common was low oil (engine), high temp (engine) and high air temp (compressor) and safety valve measuring access flow or free flow as if the hose becomes disconnected from tool (OSHA safety). Check all the safety control features of your unit for possible answer. Good luck
Posted on Oct 12, 2010
Ingersoll rand compressor 185 shuts down when pressure builds
Talk to local rental yards. I had a problem with my air compressor a while back but was able to get a rental while it was fixed. The rental company was great at helping (http://www.allpurposerental.com/product/Rental/Equipment/compressors)
Oct 21, 2012 | Air Tools & Compressors
7.5 tas high airend temperature
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Aug 29, 2012 | Ingersoll Rand Rotary Screw Compressor ...
I have an Ingersoll Rand EP30 air compressor which has emptied its coolant out of the air inlet onto the floor. What are the probably causes and their remedy?
The unit was not turned off correctly or it shut itself down due to high temp or other problem what happens is that when the compressor is loaded (producing air) the inlet valve is open which if shutdown the pressure withing the compressor will escape through this open inlet valve which will contain oil also
Apr 29, 2012 | Ingersoll Rand Air Tools & Compressors
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Ihave a ingersollrand tow behind compressor it blows the check valve due to to much pressure building in the tank i have no clue why please help
two possible problems, first and most likely is a control issue, either control regulator, inlet control valve, blow down or unloader valve, or loose or obstructed control air lines. If it is lifting the safety valve on the sump tank wet side it indicates possibly plugged separator filter or defective minimum pressure valve, most of these require a good working knowledge of the machine to repair and should not be attempted by untrained personnel.
Mar 04, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
Low sump pressure
compressor shuts down on low sump pressure
Oct 19, 2009 | Ingersoll Rand Air Tools & Compressors
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
638 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
