Question about Microsoft Xbox 360 Console
Disc will not close
When i turn my xbox360 on the disc tray open and won't stay closed. if i close it, it stays closed for a sec then opens back up.
TAPE THE THING THERE LOL JK WELL IF YOU WANT YOU CAN ROFL
Posted on Jun 02, 2008
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Xbox 360 Console: My xbox 360 will keep opening its tray and it won'...
The very first thing, I would suggest you is to check the CD cover, as sometimes labels on CDs prevent tray to close.
If that does not work then do the following.
Remove disc from the tray, make sure the faceplate is on correctly.
The faceplate is the plastic piece on the front of your console.
• Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
• If you find that the faceplate is the problem, please contact Xbox customer support to order a replacement faceplate.
If this does not resolve your issue, please try step 3 and other steps from following link.
http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907590&lcid=1033&category=hardware
If you wish you can also use following link of interactive troubleshooting wizard, which will assist you to narrow down on the issue.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xdds
This solution is absolutely free. If your issue is still not resolved, please feel free to ask.
Please rate and give your feedback.
May 03, 2010 | Video Game Consoles & Games
Old xbox360 disc tray wont close at all
open it up ( very carefully) and check to see if the disk tray end is still attached or alligned to the plastic gears that eject the tray. if so check the rubber band to make sure it has not broke or streched.
Jun 25, 2009 | Microsoft Xbox 360 Console
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Disc Tray Problem
That is how the X-Box works. It doesn't stay open, because if it stood open and it accidently dropped or anything, the drawer would break, and that would cause alot of problems with Microsoft. Thanks for using Fixya!
Jul 11, 2008 | Microsoft Xbox 360 Console
Always opening disc tray
3 things cause this:-
A Damaged Disk, A Dirty Disk, or a Hardware fault.
Below is Microsoft's doc on the issue.
http://support.microsoft.com/?scid=kb;en-gb;816779
If my advice was helpful, please vote for me!
Nov 16, 2007 | Microsoft Xbox 360 Console
DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Sep 13, 2007 | Zenith DVD5201 Multi-disc DVD Player
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
