Question about Dell XPS 400 PC Desktop
Why won't my Dell desktop computer turn on? Yesterday the monitor showed a brief message, something about the video something or the other and I powered off the hard drive. Today, the hard drive will not power on. There are green lights inside the hard drive and the power source is definitely working. My remote WiFi device is jacked into a USB port on the hard drive and it does not have power. For the past several months I've also had problems with the fan making loud noise. This computer is about 6 years old. Is it definitely dead?
  • Cindy Ard Oct 12, 2010
    Thanks a lot, Joe. I looked up my receipt and actually bought this computer December 2005. I guess 5 years for a desktop to live is still remarkable? Time to just toss it in the junk pile, huh? Cindy
  • 3,153 Answers
It sounds as if your computer is overdure for a darned good clean out inside just for starters.
Invest in a can of compressed air just for this type of job (about $3-5) and I would also invest in some thermal paste as I would also re-seat the CPU fan whilst I was in there.
If you dont feel happy working inside a computer most good computer shops will do the whole thing for around $40-60.
Doing it yourself should only cost about $10-15
I use a soft paintbrush to poke out stubborn dust bunnies but be gentle and dont tug the brush if it gets stuck. I dont use nylon brushes !!!
Once all the dust is loose esp on the fans I take the computer outside to actually blow it out.
The fan noise could well be on the PSU side and quite often does not last much more than a couple of month before it fails.
PSU are quite cheap to replace and again you could probably do this yourself but get one with a larger capacity. If yours is a 300watt supply then go for a 400 watt as it will last much longer.
Bob
Posted on Oct 13, 2010
  • 10,865 Answers
To get a desktop to last 6 years is quite remarkable. I definitely would not recommend putting any money into it. The new ones are much less money and also cheaper to operate. Joe
Posted on Oct 12, 2010
My computer had not been used in a couple of weeks and when I turned it back on it started beeping and the monitor will come on but cannot see screen
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 02, 2012 | Dell Inspiron 530 Desktop Computer
MONITOR WON'T STAY ON. not connected message then it goes off
Hook a spare monitor to the computer, if okay! problem in the original monitor, if both show the same symptom, it means the Video Graphics Card in the computer is defective. If possible change the video cord from the computer to the monitor, sometimes these cords fail.
Mar 13, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
Acer ASpire M1100 shows No Signal on monitor
Any time a monitor says "no signal" that message is originating from the monitor itself, and not from the computer. A monitor in a room by itself with no computer will say "no signal" for a brief time, if it is turned on. So, if you have tried other monitors also with no luck, then the problem is either the video adapter of the computer, or something that is keeping the computer from booting in the first place (power supply, hard drive, memory, motherboard). A power supply can be tested with an inexpensive tool. Everything else needs either a swap out with a known good stand-in, or else an expensive tool to know if it works.Does the fan come on when you turn the computer on? If so, maybe more likely to be the motherboard, hard disk, or memory. If not, more likely to be the power supply.
Feb 02, 2012 | Computers & Internet
When I plug in my computer it power up but the monitor don't . you can hear the computer running but nothing show in the monitor .
First, is the monitor turned on? Is it hooked to the computer? Do you get a message on the monitor that says something like "no signal"?
If the above is true, I would suspect that the video card on your computer is not functioning.
Mar 21, 2011 | Sony VAIO PCV-V200G PC Desktop
My pc monitor is showing a box say dmps suspend status
The DPMS standard (Display Power Management Signaling) was developed to extend the useful life of PC monitors as well as to conserve the relatively high amount of energy used by monitors when not required.
In brief terms it works as follows.
The DPMS compliant video controller and the DPMS compliant monitor use the Horizontal sync and Vertical sync signals to control the power mode of the monitor. Because there are 2 signal lines, it allows 4 modes of operation. Normal, Standby, Suspend and Off.
Go to your power management source located in the control panel and make the needed adjustments.
Dec 24, 2010 | Dell Inspiron 530s Desktop Computer
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell PC Power Save Mode
When you first plug it in and turn it on, the monitor will shut itself down with only this little note until it receives a signal from the computer to do something else.
You will have to double check the computer as well, and ensure that it too, is turned on. If this is the case, then your next step is to ensure that the monitor and the computer are talking with each other, that is, you'll have to unplug the monitor from the computer and plug it back in again.
If you do all these things, and you still have this message, then something may be wrong with your video card. At that point, you may have to consider taking it to a professional.
good luck
tony
May 19, 2009 | Dell OptiPlex GX260 Intel Desktop PC -...
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Dell Flat Screen monitor
There are hotkeys for the graphic display ctrl alt arrow key right turns normal, 90 180 270
Sep 22, 2008 | Dell Computers & Internet
Monitor and Mouse not working
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
Jul 16, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
149 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
