Question about Fuji FinePix F470 Digital Camera
Zoom error I turned my F470 camera on and received a "zoom error" bar across the screen. The lense does not move outwards after I turn the power on, nor does the plastic sliding screen close when I turn the camera off. The lense is exposed whether or not the camera is on or off. The lense does not make any sounds when I turn the camera on, but I hear (what I think) are the gears when I turn the camera off. When the camera is on, the screen is working, but the image is blurry. I tried other posted solutions including applying pressure when closing, but since the lense is not in the outwards position, it did not work. I appreciate your help.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 03, 2008
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
It says Zoom Error. On my fujifilm camera, when I turn it on. PLEASE HELP ME :(
the same thing was happening to mine, what i did was i moved the lens area back and forth,gently while turning it on and off, maybe its dust or maybe one of my little ones messed with it. i plan to keep on messing around wit it so that i won't have to be doing that, but meanwhile that worked to get rid of when it says zoom error. hope this temporary solution works.;-}
Oct 12, 2010 | Fuji FinePix F470 Digital Camera
The lens focas is messed up until i zoom it in it wasnt doing this until we took it to the beqach and it was still fine but now you hav e to zoom in to 2.4 to get the screen to not be fuzzy
Zoom lenses are very complex mechanisms with some lenses moving outward, while others are moving the opposite direction inside where you can't see them moving- the trip to the beach sounds like sand in part of the mechanism which isn't affected when zoomed out. Needs repair, but it's probably cheaper to buy another one as the repaiir will be higher than the price of a used one at around $75, and probably more than the price of a new one. Even if they do repair, you can never get all the sand out of the camera and lens.
Aug 06, 2009 | Sony Cyber-Shot DSC-S60 Digital Camera
When i take pictures, sometimes they come out with lines all over them.
shutter problem. put camera into full optical zoom, turn it to face you and angle it so that you can see into the lens without reflection. In full zoom the internal lens is right up to the outer lens so, even on a small lens such as this, when you press the picture button you should see the shutter close across fully. If it does not you will get either an over exposed or complete white out picture. Or lines across your pictures.
The shutter needs to be cleaned. There is grease in the camera for the moving parts and is probable that this is the cause for the error.
I have found this to be the case for fuji's E900, E550, F40fd, F470, F460, and a few samsung's as well.
Mar 08, 2009 | Fuji FinePix A400 Digital Camera
Zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
Sep 05, 2008 | Fuji FinePix F470 Digital Camera
Zoom Error
this usually happens when you turn on the camera with the lense cover still on. just turn it off and remove the lense cover and turn it back on again. hope this helps.
Mar 16, 2008 | Fuji FinePix S5100 Digital Camera
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Fuji FinePix F470 Digital Camera Logo
97 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
