Question about Maytag Dryers
Model# lde9206ace electric dryer; please show belt tensioner routing diagram.
4 Suggested Answers
  • 156 Answers
SOURCE: replacing maytag dryer belt
hard to explaine i will try put belt on the motor pulley then lift the belt tightner back pulley so now the belt goes around motor pulley up across the bottom of belt tightnerthen on up around drum
Posted on Feb 28, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag gas dryer belt routing
I have found a link that should provide you with the belt routing diagram you are looking for.
Any trouble,post me back.
Dave E. (Illeagle)
http://www.repair-help.com/kb/index.php?article=105
Posted on Jun 02, 2008
captaynkyrk
  • 170 Answers
SOURCE: dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
I need a diagram on how to route the belt on a maytag atlantis dryer model number mde7600yw and also a diagram of the tensioner spring for the tension pulley
Hi and welcome to FixYa, I am Kelly
The flat side of the belt goes against the drum and the routing diagram can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
If you need more assistance after viewing the diagram and attempting to install your belt without success, just respond here and I can help you.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Where do i find belt routing diagrams?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Depending on the model Kenmore you have, you will refer to either diagram H, B, or K. If you have trouble being able to determine which diagram you should use, please post back with your complete MODEL NUMBER so I can assist you further. I hope you find this information helpful.
Apr 21, 2010 | Kenmore 62602 Electric Dryer
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Dryer belt routing
it should loop aroud the drum then form a small loop to go around the motor . you may have to push the tensioner forward to get the belt on the motor. if not go to the parts store and they can show you
Apr 08, 2009 | Dryers
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Replace dryer belt
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
203 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
