Question about Saeco Vienna Espresso Machine
Vienna Black suddently stopped working. No lights or anything.
Removed the Brew Group, cleaned and replaced, When reinstalled the machine made some grinding noises for a few seconds, then proceeded to work normally for one cup of coffee. At that point all lights went off and machine will not restart. Outlet power is good, limit switch for drain pan and brew group click when pushed. (I manually pushed on them to see if I could get unit lights to come on.)
  • 1 more comment
  • PBMeisel Jun 01, 2008
    I have taken the unit apart, and found nothing binding. The brew group appears to work freely. Arrows are aligned for proper reassembly. The driving portion of the shaft does not want to turn on the output end, but I would expect that as there is a significant gear reduction on it. Also, the noise occurred during what should have been the grinding cycle and I have cleared the grinder and it appears to be free. I can tell you that the problem did not start until after the machine completed the brewing cycle and the milk frothing cycle. Once I had completed steaming, the lights all simply went out. I would also expect that there would be some sign of life during the warm up part of the cycle even if one of the mechanisms were jammed.
    This unit is just under 2 years old, don't seem to have any warranty paperwork with the unit. I pulled the whole thing apart and could not find a fuse anywhere. Had power at the filter coming in (both upstream and down). Had power at the circuit board input. The on-off switch did indeed turn power on and off. Could not really diagnose any further than that.
  • PBMeisel Jun 05, 2008
    I ended up finding the solution to my problem without expert help. I found that there were two things that would keep all of the lights from coming on when the unit was plugged in. The first is a limit switch that detects if the case is in place. It is on the front of the unit behind the upper part of the panel If this not engaged or is defective, the unit will not get any power. The second is that there are 2 thermal sensors on the bottom of the boiler. If tripped, they need to be manually reset by pushing them until they click. Hope this helps the next guy.
    Genius:
  • 3,587 Answers
The grinding noises are worrisome. Sounds to me as though something was in the wrong place, and once it worked for one cycle, whatever was left inside, or ??? would have frozen the unit. Sounds to me like you'll need to take it completely apart, to see what's causing the lock up situation.
Posted on Jun 01, 2008
  • Patrick Michaels
    Patrick Michaels Jun 01, 2008
    I agree..but when the lights are out, that's a control circuit issue, and something is telling that board to disable..could be an on board fuse, or device..
    this thing under warranty, by chance?
  • Patrick Michaels
    sounds like you're at an impasse.
My descaling and coffee grounds drawer light were blinking alternatively. I did as the instructions said and turned the machine off then back on to no avail. So I removed the grounds drawer and brew...
Make sure the brew group is in
rest position; the two references
must match.(look at the marks/arrows on the side of the brew group)
Make sure the components are in
the correct position.
The hook shown must be in the
correct position; to check its
position, firmly press the "PUSH"
button.
Jan 14, 2011 | Saeco Odea Giro Plus Coffee Maker
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco Vienna wont turn on
dont worry if it was working good before the clean up the brew group is not install all the way in remove it push it in untill you here a click the brew group is not all the way in and doesnt push the on switch when you push it in wiggle it
THANKS FOR USING FIXYA
PIERRE
Feb 17, 2008 | Saeco Vienna Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Vienna deluxe can't get dump box back in - brew group flap in the way
Leave the dump box out. Use a spoon to hit the switch where the dump box would normally hit. Hold the switch until the flap is no longer in the way then replace the dump box.
Espresso Machine Service
www.cerinicoffee.com
Nov 23, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
101 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
