Question about Dell G2410 Monitor
How do I rotate dell G2410 monitor to portrait position?
  • Dell Master
  • 32,281 Answers
Normal 0 To rotate the image, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798302-upside_down_display
Posted on Oct 12, 2010
Dell 2208wfpt settings for portrait rotation?
Andrew Scharlach,
Are you changing the rotation using the ctrl+alt+right arrow. left arrow or down arrow? That is how i change the rotation on the screen. If needed lower the resolution in the display settings in control panel.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 24, 2015 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. Sprint6@zoominternet.net for personal help with this unit.
Dec 03, 2013 | Dell E197FP LCD Monitor
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
The creen on my laptop is rotated sideways how do I fix it everything on my screen is sideways and i need it to be up and down so i can read my screen right side up on my laptop computer
Based on your brief description, I think your problem is correctable in the control panel under monitor settings. Depending on your operating system (XP, Vista, Windows 7) you will need to find the monitor settings and look for the advanced section for the Nvidia Video Card. In there you should find a setting to flip the monitor view between Portrait and Landscape. The settings may be named differently, but there will likely be a graphic representation to show you the different settings available.
Nov 29, 2010 | Dell Inspiron 1525 Laptop
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
Change Landscape to Potrait veiw
Hello, You need an application called HP MyDisplay, you can download this at the link below, this app will register in which way the monitor is (landscape or Portrait) and when you pivot (rotate) the screen it will rotate the screen as well.
Download: http://www.portrait.com/dtune/hpw/enu/upgrade_instructions.html kr Gijs
Sep 10, 2009 | HP Pavillion s7420n PC Desktop
Change from landscape to portrait
There should be an option either in the monitors drivers or in Windows Control Panel that sets it to portrait mode. I hope this helps, Yannick.
Jun 06, 2009 | HP L1925 19" LCD Monitor
Can I swivel monitor & view portrait?
Hi There,
on most monitors, no you cannot view the screen on portrait.
There are some larger, wide screen monitors that I have seen that allow you to twist and see the screen and picture vertical.
You have to get a monitor specifically to do this in the specs of the monitor.
Here is a Google search on models that you can do this with.
http://www.google.com/products?hl=en&q=portrait+monitor+lcd&um=1&ie=UTF-8&ei=PtXmSYaFIKCCtgOBguXrAQ&sa=X&oi=product_result_group&resnum=1&ct=title
Apr 16, 2009 | Computers & Internet
Portrait display
Hi...there!
Sure you can... just go to your toolbars bottom R/H side and look for a Graphic Card settings for example ( Nvidia or ATI settings) Then right click and look for a rotation settings from there just followed the settings... To adjust the display, open your on screen display on your LCD monitor and look for Auto Adjust by using (- +) buttons... Have a nice day!
Oct 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Movie mode playback, if filmed in portrait position can you rotate the movie after to view it the right way up?
The only way to see the movie the right way up is to turn your monitor on its side, I'm afraid. You also might be able to take it to a professional studio, who might possibly have the capability, but you will still wind up with a lot of blank space to the right and left of your image.
Oct 24, 2007 | Fuji FinePix E550 Digital Camera
Dell G2410 Monitor Logo
350 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
