Question about Sharp EL-531VB Calculator
How do you restore the Sharp EL531W calculator to the original settings.
  • 3 Answers
For the manual see link
http://sharp-world.com/contents/calculat...
The downloaded manual pages 3 and 4 states, click the "setup 03" key and it will change to normal mode.
10000/8.1=1234.5678901 (normal mode)
setup 00 setup13 1234.568 (fix mode tab=3)
setup 01 sci mode
setup 02 eng mode
setup 03 normal mode
or just click the reset switch behind the ( Sharp el531w ) calculator, data will be deleted.
Posted on Jul 12, 2013
4 Suggested Answers
oneplusgh
  • 100 Answers
SOURCE: How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Posted on Jan 13, 2011
  • 7993 Answers
SOURCE: how to restore original settings for fx-991ms
Here it is.
Posted on Jul 28, 2010
  • 7993 Answers
SOURCE: How to reset to original settings?
1. To restore the default setting you have to reset the calculator:
- With the calculator switched ON press the [2nd][+] [ENTER] Move the cursor down to Reset or press the [7] key.
-Choose to reset [RAM] ( 1: all ram; 2: defaults) or [ALL] (1: all memory. Whatever choice you make needs to be confirmed in a subsequent screen.
To reinstall the applications you need a TI silver cable, and the TI Connect software. Install the software before connecting the calculator to the computer.
Then you go to the education.ti.com web site Unfold the DOWNLOADS menu, choose Apps,Software,Updates submenu. Click TI83Plus/TI84PLUS family link and download what ever you want on your computer.
When you are done, connect your calculator to the computer, execute the TIConnect software . You can then drag and drop on the TIconnect window the app you want to restore.
Hope it helps.
Posted on Aug 18, 2009
Turn off the fix mode
Press SETUP and choose 0 for FSE. Then choose 3 for Norm 1. This will put the calculator back to the original setting.
Mar 20, 2014 | Sharp el-531x scientific calculator
HP 48 G
Well, before trying something like opening the calculator, I'd advise archiving anything that you want to save to your PC. But what's done is done.
Are you sure that you're inserting the batteries with the proper polarity? Are you sure that the batteries are good?
It does sound to me like some sort of hardware problem, but strange things could happen if RAM gets corrupted (such as by being without power for too long).
It could be that the calculator really is on, but isn't displaying anything. The following solutions assume that the calculator is on.
Try a warmstart, that is hold down the ON key, press and release C, release ON.
If that doesn't work, try forcing a warmstart with a paper-clip reset. Remove the upper right (as viewed from the back) rubber foot. You'll see a small hole with the letter R next to it. Insert a straightened paper-clip (or something similar) straight in as far as it will go, and release it.
If that doesn't work, and you're willing to lose everything you had stored on the calculator, try clearing all user memory. Hold down ON, hold down A, press and release F, release A, release ON.
Regards, Sharp el531w
Jul 11, 2013 | Office Equipment & Supplies
Hi eamon at hom,
Jan 13, 2011 | Sharp EL-501WBBL Calculator
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
Hope it helps.
May 30, 2009 | Texas Instruments TI-84 Plus Calculator
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Nothing happens when I press a number??
There is no lock button. Calculator may be configured to be in computational mode you are not familiar with: It may be set to do base calculation on base 5, hence the p (pental). Press the reset button on the back, and the default configuraion will be restored.
You should give some time to learn the different mode of calculations.
Hope it helps.
Feb 01, 2009 | Sharp EL-531VB Calculator
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
Date:
date is restored.
Time:
time is restored.
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Replay Button
hit (shift) (clr) and Number (3)
your calculator will be reset to the original factory setting.
Naveen
Feb 06, 2008 | Casio FX-300MS Calculator
Sharp EL-531VB Calculator Logo
1,588 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
