Question about Toro Lawn Mower With Toro Power Tools
Toro workman 3200 has a surging problem - Toro Lawn Mower With Toro Power Tools
Overheating problem
i would take a close look at the water pump
if the water isnt moving through the system it basically becomes a kettle
thats why steam comes out of the bleed nipple
Dec 09, 2016 | Cars & Trucks
My toro 3200 seems like the transmission is locked
check the brake make sure its disengaged
if it wasnt moved in awhile brake can stick
Feb 07, 2015 | Toro Mowers - Time Cutter SS3200 32""...
Toro workman 3200 wont crank
Try a little starting fluid directly into the carb. If that works, then you have narrowed it down to a fuel flow problem. On mine, the fuel pickup hose cracked where it came through the gas tank. I replaced it and it fired up on the third pull.
Mar 08, 2014 | Toro Garden
Where can I buy Toro Workman 3200 carburetor?
go to Toro commercial service center. They are expencsive. I have the same set up as your workman for fertilizing and spraying. Where are you located? I am in Holland,, Michigan
Dec 12, 2013 | Toro Workman 3200
Out of transmission fluid in my toro workman 4200 4wd
According to the service manual, the transaxle uses 8 quarts of DEXTRON III transmission fluid. It also is the source for fluid for the hydraulics.
Dec 07, 2012 | Toro Garden
Toro 20016 engine surges up and down - then stalls
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Jim
May 28, 2009 | Toro Lawn Mower With Toro Power Tools
Engine surging
sounds like it is "hunting". it is a fuel mixture issue.
May 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
226 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
